Question about Jabra EasyGo Bluetooth Headset
How do I retrieve my security code for the internet for Easygo
I can{t find my security code for Easygo to get access to the internet
How do i pair my jabra easygo to my phone
Hold your blutooth switch on button at few second the light at bluetooth is starts to blink now open bluetooth menu in mobile select pared device and select search new device or go to blutooth menu and select search audio enhancement
Apr 20, 2013 | Jabra EasyGo Bluetooth Headset
Set up a security code on a vtech phone
If you mean the remote access code, follow the instructions on page 39 of this manual.
Nov 28, 2012 | VTech Communications Vtech CS6429-3...
I cannot connect a new computer as I have forgotten my security code/passphraise for the router please email my code
Hello.
You will have to reset your router to factory defaults. It is impossible to retrieve a passphrase if you can't remember it.
Find the little hole near the power plug on your router and insert a straighten paperclip for 10 seconds while your router is powered on.
This procedure will reset your router and you will have to start over with the setup CD or entering by your internet browser with 192.168.0.1
Hope this helps and don't forget to put back security feature on your wireless access point!
Feb 13, 2011 | Cisco (WS-X3011) Router
I forgot my security code, please i want to know... thanks
You can retrieve the security code through your router setup page. So, access router setup page. If you don't know how, check this blog How to Access the Router Setup Page
Nov 15, 2010 | Computers & Internet
I forgot my security code. I have a linksys Wireless - G Broadband Router. Can you tel me how to find the security code so I can connect my lap top computer? Thanks
Hello. You will get the security through a router's page. If you don't how to access the router's page and retrieve your password from there, just right-click the title How to Retrieve Wireless Password or PIN of your Linksys Router .
Nov 14, 2010 | Linksys Wireless-G Broadband Router
On my computer, i know exeactly where my WEP key is located. I know it's eight characters long but it's locked on my computer. All I see are eight security dots and the 'show characters' option is blanked...
You cannot retrieve or see the security key on the computer. There are software available but you may have to search for them if its free. This key can be retrieved from the wireless transmitter known as the access point or wireless modem or wireless router. Open the router web interface on a wired connection. This interface will not open on a wireless connection. After opening, under the wireless section, click on security and there you can see your WEP or WPA or WPA2 key written.
Thanks and regards,
If you have any further clarifications, revert!
Arvind S Iyer
Sep 23, 2010 | Microsoft Computers & Internet
I have a gemini home security system and do not know the access code. Can u help me?
Your system is manufactured by Napco Security Systems of Amityville, New York. Call them at 1-800-645-9445 and request that they provide you with a security dealer in your area. The dealer should be able to access the system's internal data and retrieve the user code for turning on and off your system.
Jan 21, 2010 | GE Security Simon 3 Wireless Home Security...
I'm sorry to say that you won't be able to retrieve your security code unless you go to your mobile company's store, and show some proof that you are the cell phone's owner (Driver's License would be good). Then they will reset it for you, and you'll be able to access what you couldn't before. Hope this helped!
Dec 05, 2009 | Nokia 5310 Cellular Phone
Retrieve Messages when away from home
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Oct 24, 2008 | Sony TAM-100 Digital Answering Machine
How does e-mail work through the Prestige 310 ?
It depends on what kind of IP you have: Static or Dynamic. If your company has a domain name, it means that you have a static IP address. Suppose your company's e-mail address is xxx@mycompany.com. Joe and Debbie will be able to send e-mail through Prestige 310 Internet Access Sharing Router using jane@mycompany.com and debbie@mycompany.com respectively as their e-mail addresses. They will be able to retrieve their individual private and secure e-mail, if they have been assigned the proper access right. If your company does not have a domain name, it means that your ISP provides you with a dynamic IP address. Suppose your company's e-mail address is mycompany@ispname.com. Jane and John will be able to send e-mail through Prestige 310 Internet Access Sharing Router using "jane" and "john" respectively as their e-mail addresses. Again, they will be able to retrieve their individual private and secured e-mail, if they have been assigned the proper access right.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Jabra EasyGo Bluetooth Headset Logo
16 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
