Question about Extech CTH10 Radio Controlled Wall Clock Hygro-Thermometer with Super Large 4.3-Inch 109mm Digit Clock Display, Receives Time Code from NIST Radio Station WWVB North American region, Large LCD displays Time, RH%, Temperature, Year, Month, Date, and Day; UPC
HOW DO YOY SET TIME ZONE
CAN SET TIMEBUT STAYS IN PACIFIC ZONE
How do i change time on my lenovo tab to pacific time
Go to settings, Time and Date, make sure that the time zone is not gray out, if it is, disable automatic time zone, scroll down to the time zone and change it to Pacific, which is GMT -08:00
Mar 04, 2015 | Audio Players & Recorders
Need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
May 06, 2012 | Audio Players & Recorders
I need to set the time to eastern standard time. When I do set the time it goes back to pacific time after midnight.
If You have'nt done so already. You have to go to time and date and click the Time Zone at the top
& if it shows Pacific Time America - Canada . Click the down arrow in time zone and
change that to Canbera,Melbourne, Sydney by scrolling down to see near the bottom of the page
Canbera -Melbourne -Sydney & click apply and OK
Hope this Helps
BillyG
Jul 11, 2011 | Medion md40298 Notebook
I want to set my EnviraStation DWS220 to the right time zone.
TIME ZONE SELECTION
Press SET" button on the front of home receiver to select from the following
time zones in the U.S. (zone is displayed in the upper right hand corner of
time display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Tim
Dec 05, 2010 | Measuring Tools & Sensors
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
How do you set time zone model 3229-1
Press the Mode button to display the alarm time then press the Adjust button till you get tot the corret time zone, press Mode again once have found the coreect timezone.
Jun 22, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Got mine yesterday and its set on eastern time zone, i need pacific time zone and it will not sync, how to manually adjust ime
You should be able to set your watch to the Pacific time zone.
f you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
You shouldbe able to find the setting method in the manual.
May 12, 2010 | Casio Atomic Timekeeping WV58A 9AV Watch
We have an atomic clock with calendar and temptature on it. We changed the battery and it is now on Eastern time zone, not Pacific time zone. How do we set it? It is La Crosse Technology Radio Model #...
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Feb 20, 2010 | La Crosse Radio Controlled Atomic Clock
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
Honeywell RC182WB Atomic Alarm Clock with Temperature--stuck on pacific time!!!
I KNOW HOW TO FIX IT!
Take off the battery cover, and take the batts out, leaving the outside thermometer working...
You will have to reset everything but it automatically detects your time zone!
I just did it literally 2 minutes ago!
Nov 23, 2007 | Honeywell RC182WR Atomic Alarm Clock - Red
Extech CTH10 Radio Controlled Wall Clock Hygro-Thermometer with Super Large 4.3-Inch 109mm Digit Clock Display, Receives Time Code from NIST Radio Station WWVB North American region, Large LCD displays Time, RH%, Temperature, Year, Month, Date, and Day; UPC Logo
29 people viewed this question
Top Extech Home Experts
Donni Steen
Tom Chichester
Are you an Extech Home Expert? Answer questions, earn points and help others
