Question about E-Machines eMachines Desktop PC
Black screen beeping
Plugged in computer it beeped and the screen is black
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Might be an issue with RAM.
Posted on Jan 29, 2015
My Dell laptop makes 12 beeps and won't start, why?
Unfortunately, they are bad news and omens of *****!
  • Beep Codes - General Hardware - Laptop - Dell Community en.community.dell.com > ... > Laptop > General Hardware There is a comment in the User's Guide that you should make a note of beep codes when contacting Technical Support but there is no list of the beep codes - this ...
  • Dell Optiplex and Vostro Beep Codes and Error Messages ... www.dell.com/support/Article/us/en/19/SLN143065/EN 1. OptiPlex Beep Codes. The computer might emit a series of beeps during start-up if the display cannot show errors or problems. This series of beeps, called a beep ...
  • Beep Codes and PSA Diagnostic Chart - Desktop Wiki - Dell en.community.dell.com > Support Forums > Desktop > Desktop Wiki Identifying Dell Computer Models Using the Model Code. On Sept 26, 2005 the System Setup program on certain Dell Dimension™, Inspiron™, and XPS™ computers was ...
  • Alienware Computer Does Not Turn On or Go Into Windows ... www.dell.com/support/article/SLN114868/en Dell support article tagged with ... The following tables illustrate the Beep Codes for Alienware Mobiles and ... For a laptop computer see if you can access the ...
  • Dell Inspiron 15R (N5110) Beep Codes Diagnostic Indicators blog.parts-people.com > ... > Inspiron 15R (N5110) How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming ...
  • Dell Motherboard Beep Codes - What They Mean www.brighthub.com > ... > Computer Hardware Support 2010-05-23 · Technicians and computer users alike can use beep codes to troubleshoot hardware problems on all kinds of machines. This article lists Dell beep codes ...
  • Dell BIOS Post Codes - BIOS Central www.bioscentral.com/postcodes/dellbios.htm Dell BIOS Beep Codes; Dell BIOS System Messages; Dell BIOS Post Codes . Dell BIOS Beep Codes:
  • Step-By-Step: Deciphering BIOS beep codes - TechRepublic www.techrepublic.com/article/step-by-step-deciphering-bios-beep-codes Discover what the beeps your computer makes at start up mean. ... Step-By-Step: Deciphering BIOS beep codes. ... Dell BIOS Beep codes for Dell computers ...
  • http://www.bing.com/search?q=dell+laptop+beep+codes&qs=AS&pq=dell+laptop+beep+codes&sc=2-22&sp=1&cvid=768D6F3CC9284B039CE5B3AB707EFF02&FORM=QBRE
    Jul 31, 2016 | Dell Computers & Internet
    Hi. I Inherited a DELL Poweredge 1600SC server. When I switch it on, it powers up but the screen remains blank [black without any beeps]?? I remove all the memory and switched it back on again = NO beeps....
    I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
    Aug 01, 2013 | Dell PowerEdge 1600SC Server
    My acer aspire one notebook laptop when I push the power button comes on and shows the start up screen and then the screen instantly goes to this black screen with a little white line blinking in the top...
    Perhaps you've built a computer and are turning it on for the first time, or you've owned this computer for awhile. Either way, you may encounter an issue where the monitor shows a black screen and the computer is beeping. There are several causes and solutions for this problem.
    1.Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
    2.Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
    Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
    3.Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
    4.Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
    Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
    I hope you find it very helpful.
    Aug 25, 2011 | Acer Aspire One PC Notebook
    Everytime i boot my pc,it beeps 2x,then black screen,so i have to reboot again
    The beeping is caused by your computers POST( Power On Self Test - learn something new everyday! ;) )
    Find your motherboard manual, and have a look in it for beep codes, or error codes. The number of beeps will let you know what kind of problem you're dealing with.
    If all is well in POST, your computer should only beep once, and continue.
    Can you get into BIOS at all, or does it just show you your videocard info on bootup, then black screen?
    May 27, 2011 | Microsoft Windows XP Professional
    VA1703wb... Monitor beeps when I turn on the pc then goes black
    Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
    Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
    Post back what you see inside so we can guide you further and it will help out other people in the future also.
    http://en.wikipedia.org/wiki/Capacitor_plague
    http://www.badcaps.net
    May 06, 2010 | ViewSonic VA1703wb Monitor
    Black screen when i turn on the computer
    post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
    when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
    Apr 25, 2009 | Compaq Presario 5000 PC Desktop
    Black screen with error codes
    I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
    Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
    Dec 16, 2008 | Computers & Internet
    Black screen
    The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
    Feb 04, 2007 | Microsoft Realsync DS771 17 Black LCD 8ms...
    E-Machines eMachines Desktop PC Logo
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
