Question about Eastern 2010 Kia Sportage - 2WD, 2.7L V6 - Catalytic Direct-fit Catalytic Converters - 49-State Legal
Lights on my 2010 Kia Sportage started going out. I replaced the front right flasher and the rear right flasher and light bulb . Three months later took my Kia in for recall work on the brake lights.
NOT SURE JUST KNOW IT IS A V6
Turn of the brack lights when the engine is turned of on my Kia sportage 2010
The brake light switch may be sticking on. It should be replaced.
Mar 02, 2015 | 2010 Kia Sportage 2.0
2011 kia optima fog lights go on only when right blinker is on, just changed front side marker bulb and is still doing the same thing, blinking fast but no other lights are out.
fast blinking is a sign that the flasher relay has a fault , change that and i would expect the fog light issue will resolve as well , as i expect the flasher relay is trying to earth through a different circuit
Jan 20, 2015 | 2011 Kia Optima SX
2006 kia sportage ex..engine was running..now want spin over
The SRS is connected to the fuel pump as a safety measure. What happened is the fuel pump cutoff is active now.
Dec 26, 2014 | Kia 2006 SPORTAGE EX Front Right Window...
When i turn the signal lights for left or right turn the emergency flasher start flashing all four turn signal lights. the emergency flashers work ok
ck your turn signal switch wiring connector because it is more than likely has been hot and melted some connections.
Oct 18, 2014 | 2000 Kia Sportage
1997 Dodge Neon left signal lights work great. Right side blinks very fast.
Has the car been in a fender bender ? check for wiring going to the front and rear lights to see if on has rubbed into a ground wire or the body. ( even if there has been no accident.)
Apr 18, 2013 | 1997 Dodge Neon
My left flasher dont work,can younpls help?
it would help to tell what its doing or not doing... front? rear?comes on, wont flash, both rear brake lights work? running lights? right side works OK? turn the hazard flashers on and look at what bulb isnt flashing and start with replacing it. If that doesnt work, make sure power is on the wire to the bulb.
Dec 05, 2010 | 2005 Chevrolet Silverado
When putting on the left or right turn signal or flashers the two front lights do not flash. Also noticed that as the rear flash, it is faster than normal.
sounds like a bad bulb or flasher...
If the light outside light up , but do not flash.... then plink the flasher ( round silver bulb in the fuse box) with a finger and see if they start working...
Sep 24, 2010 | 2004 Toyota 4Runner
Turn signals blink fast (lights still work)? what
Hello. This happens when one of the bulbs is starting to go bad. pull all of the turn signal bulbs and look carefully at each one. you will find one with the filaments crossed. Replace that one. J.
Jun 15, 2010 | 1998 Honda Accord
Right turn signal blinks very fast I have changes the light and all other lights on the rear but the problem still exists. 2003 passat wagon 4 cylinder
I had the same problem with my 2002 Jetta. The front right bulb wasn't working. I replaced the bulb and it still didn't work, that's when I found that the bulb could be inserted backwards! I turned the bulb 180 degrees and now the blinkers are normal.
Another thing I noticed was that one of the contacts on the bulb and socket were burnt. I bought the car used in 2010 and I verified that the flasher relay was replaced as part of the recall, so I don't know if the damage was done before the relay was replaced or I still have a problem. I will keep an eye on the bulb about one a month.
May 21, 2010 | Cars & Trucks
Eastern 2010 Kia Sportage - 2WD, 2.7L V6 - Catalytic Direct-fit Catalytic Converters - 49-State Legal Logo
111 people viewed this question
Top Eastern Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Eastern Health and Beauty Expert? Answer questions, earn points and help others
