Question about Motorola Mobility Replacement Parts Only For Digital Video Baby Monitor, Camera Only
Monitor not working
Cannot view anything on monitor
Mac book air to view sonic monitor & I can't find icons or anything just grey screen and mouse...anyone can help?
Go to System Preference on your Mac which is a setting icon (Gear) then go to DISPLAYS > ARRANGEMENT >CHECK ON THE MIRROR DISPLAYS.
You can also set the monitor arrangement sideways or upside down.
Hope this helps.
Mar 06, 2013 | Computers & Internet
It's getting power but do not display anything on the monitor
1st unplugging your monitor cable what u see pls reply
Jul 31, 2012 | HP Compaq Evo w4000 PC Desktop
Picture is not coming on monitor when I boot my system.System beeps while booting.I can also able to shut down the system after booting assuming it is on windows desktop without viewing anything on...
Things to try:
1. Check if your monitor is turned on.
2. Turn your monitor's Brightness and Contrast settings to the highest.
3. Try replacing your monitor's cable a with a new one.
Mar 12, 2011 | Computers & Internet
My dell inspiron 1300 notebook seems to be working but I cannot see anything on the screen. I was told to hook it up using a VGA cord to a monitor to solve the problem. It doesnt seem to be working and...
after u connect it to VGA u need to change the display signal interface to monitor from lcd, the option is available in display properties in Control panel
under Display prop, go to Settings/Advanced/Monitor or Adaptor depending on the choice.
there u will get LCD or Monitor or TV to chose.
the big ? is if you cant view anything on the LCD laptop how will u do it....?
check if u can view any bit of display in ur laptop like a filim negative....if it's totaly dark then u may visit a tech shop to replace the lcd screen
Jan 27, 2010 | Dell Inspiron 1300 Notebook
I'm getting power..but its not booting up
have you got any other external monitor? try to get screen with external monitor if you will have your lcd is not working, if you wont have any view , something wrong with mainboard or CPU
Jun 27, 2009 | IBM ThinkPad T30 2366 Notebook
View two different pages on two different monitors.
Sounds like you need to enable dual monitor in you display settings. There are three options there that will allow you to either 1. view one monitor at a time (sounds like your problem) 2. duplicate the same desktop on both monitors 3. expand desktop to the second monitor. (this is the one you want) On my Hpdv9000 it is accessible by right clicking on the desktop and selecting Nvidia Control Panel, -> Displays -> Multiple Displays. From here you can specify which monitor is your primary monitor where your start menu desktop will appear. But if you do not have an Nvidia Graphics card, which is typical of Hp's (your laptop's make you did not specify) this will be not much help sorry.
Dec 29, 2008 | HP w2207 Monitor
The Monitor on my Nikon D80 does not show any image when I try to take a picture - The viewfinder is ok and the camera takes a picture ok and displays it for about 4 seconds on the monitor after taking it....
You can switch it off so as not to show the picture after you take one.
You cannot use the monitor to show images as you're taking them. The D80 does not have a Live View capability.
Sep 19, 2008 | Nikon Cameras
When viewing movie clips at anything above 480p the characters are blue
NO CUASE ONE DAY IT MIGHT WORK SO DONT I KNOW ALOT ABOUT COMPUTERS CHECK THE MODEM SEE IF ANY THING ISNT WORKING
Nov 30, 2007 | HP Compaq WF1907 Monitor
Monitor goes dim
Capacitor is going bad in powersupply.Leaky!
Sep 08, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Grey Squares on the monitor
Try reducing the resolution, Since the CRT you are referring to is old monitor, it might not support high resolution.
Feb 08, 2007 | TTX Medallion Series -8570 (White) 15...
Motorola Mobility Replacement Parts Only For Digital Video Baby Monitor, Camera Only Logo
49 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
