Question about Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Asking for the language how do I exit
It's on the language screen
Htc 3600 problem in chang language i like to
  • Hi,
    To change the language on your HTC P3600, this is what to do.
    Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings."
  • Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
  • Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose.
  • Regards
    Jun 29, 2011 | HTC Wildfire Cell Phone
    I own a Gateway nv7802u laptop computer that has recently crashed. When I turn the computer on, I get the normal Gateway startup followed by a black screen that says: PXE-E61: Media test failure, check...
    Check and see if the hard drive came loose check the bios to see if it is recognized..It is saying there is nothing with an O/S on it and when you put the disk in it does not register a hard drive to restore..Check the hard drive and start the computer up and see if you can cancel the restore and start the laptop up regular..
    Mar 28, 2011 | Gateway NV7802U Notebook
    How to change the language of htc
    1 Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings."
    2 Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
    3 Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose.
    But base on the HTC website if you want to change the language of your OS you may refer to there disclaimer: The PDA phone's OS language may not be changed according to HTC agreement with Microsoft. It is therefore important that you specify your preferred OS language when you purchase your device.
    Mar 15, 2011 | Computers & Internet
    I cant change the language on my htc s730
    Touch "Settings."Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
    Mar 14, 2011 | Computers & Internet
    I have htc touch diomond but my language is on dutch and i like it on english.please write me how can i change my language step by step into english.tnx
    1. Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings." 2. Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit." 3. Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose.
    Mar 02, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
    How to get subtitles in english .they are coming in another language
    Hello
    To select the language, do the following.
    [1] Press Menu and the press Left or Right arrow on the remote to select language option.
    Choice of language selection [3] will appear on the screen.
    English, Espanol and Francias
    [2] Press Up or Down arrow to select the desired lannguage you want to be displayed on the screen. Then press ENTER.
    [3] Press Menu repeatedly to exit the Menu screen to be cleared.
    OK.
    Jan 11, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
    How to change language on htc duo
    1. Hi,
    2. Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings."
    3. Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
    4. Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you choose. THANK YOU.
    Dec 21, 2010 | HTC Touch P3452 Smartphone
    Russian to english?
    to change your language setting back to english Turn on your HTC Touch. Touch "Start" on your Home screen. Then "Settings."> System > Regional Settings. Select the proper region for english language then. Touch "OK" when prompted and "Exit."
  • Confirm that your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in english.hope this helps pls do let me know.thanks.
  • Jan 11, 2010 | HTC Touch Cellular Phone
    I have GE XS Stereo Commercial Skip Model 27GT619
    1. On the front of the TV press the MENU button to display the MAIN MENU.
    2. Scroll through the choices using the VOLUME up and down buttons
    3. When positioned on the selection you want press the MENU button again.
    4. The first SETUP screen displays, asking you to select a language.
    5. Scroll to the desired language ENGLISH, FRANCAIS or ESPANOL and once it is highlighted in green press the MENU button to make finale selection.
    6. A SETUP screen appears asking if you would like the TV to search for all channel
    7. 1. Yes
      2. Skip this step
      3. 0 Exit
    8. Complete the SETUP routine or skip any of the steps and return to them later.
    This information is from the User Guide that came with our set. Good Luck.
    Jun 11, 2009 | GE 27GT271 TV
    Select Language
    With electronics sources or monitors,asking a language preference is a first or early step in initial programming.To analyze the source of the "which language " request--dis-connect the cable box temporarily and hook up signal direct to tv.If ? is still there,the tv is asking it. If ? is gone,then the source box was asking. Any further assistance needed,please let me know.
    Oct 03, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
    Sylvania 6719DC 19 in. TV/VCR/DVD Combo Logo
    24 people viewed this question
    Top Sylvania Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
