Question about Neewer Mini 12V/24V LED Display Digital Car Volt Meter Vehicle Voltage G
I would like to know , I have a new newer digital voltmeter what and were does the yellow wire go
Would like to know were does the yellow wire go and whats it for
04 crown victoria not turning over battery gud new alternator
connections? at the battery posts are good? power available at starter relay? car is in park or neutral? now you need to verify theres power on the start wire. the small trigger wire for start enable. if a test light or voltmeter wont show power during crank, then it may be theres a problem in the neutral safety. it has to know the trans is out of gear. newer vehicles have mlp sensors instead of neutral safety switches. its time to get a service manual and determine the pinpoint test for this vehicle
Apr 17, 2014 | Cars & Trucks
Wire diagram for the a/c cooling fan.. 1991 Jeep Commache
I am sorry but fixya doesn't have any wiring diagrams. They are copyrighted and not free to share.
Jul 22, 2012 | Jeep Comanche Cars & Trucks
I need to know which wire is ingnition power and which is constant power in a 1993 chevy corsica radio system
on your car the ingition wire is yellow also known as the switched 12V
http://www.the12volt.com/installbay/stereodetail/508.html
i recomend that you double check all the wires stated on the website using a voltmeter
May 14, 2010 | Car Audio & Video
I have a 2000 dodge ram with the 5.9 engine is not getting fire.i have replaced coil,cap,rotor button,and wires. possibly an ecm prob?
check the camshaft position sensor inside the distributor. remove the distributor cap. take a volt meter and use either a paper clip or a small pin to insert into the back of the distributor connector (yellow wire). connect the positive side of voltmeter to yellow wire. rotate engine with starter until the rotor is pointed toward the rear of vehicle. with the ignition on( engine not running) the voltmeter should say 5 volts. if there is no voltage check the voltage on supply wire . with the key on there should be approximately 8.0 volts. if voltage is presant, install the probes of the voltmeter into the signal wire (tan/yellow) and crank the engine over to observe the voltage reading. the meter should read 5.0 volts indicating that the ignition signal is pulsing properly. if the camshaft sensor fails either test (replace it).
Apr 24, 2010 | 2000 Dodge Ram 1500 Truck
I have a new ignition switch with sol, bat, and acc on the back the wires consist of yellow with red stripe, purple and orange what goes where please. this is on a 2.5 litre omc engine.
You will need to use a voltmeter to test the wires. Ground one side of the voltmeter and check the wires with the other. One of the wires should give you the constant positive voltage. This wire should go to bat. Using the positive wire you found above check to see, by touchiung other wires to the 1st wire, which will give you ignition and which tries to "start" the engine. My educated gues would be that the purple will be your starter wire which will go to the sol, the orange will go to acc, and yellow with red will go to bat.
Mar 11, 2010 | Boatmates products are the final word...
Tv keeps turning itself off
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
Oct 10, 2009 | Televison & Video
Replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Jun 24, 2009 | Goodman CKL30AR30 Air Conditioner
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is www.crutchfield.com. Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
My camera wont charge
1 Is the charger unit OK? Connect a voltmeter to the camera plug to test the voltage. While connected, wiggle the wire at both ends to test if it is broken. If not OK, replace charger unit.
2 Is the battery OK? Test battery voltage with voltmeter. Connect crocodile clip leads to the voltmeter probes and a good charger. (A cut paperclip can be inserted into the center connection of the charger.) Check that meter reading is positive, and then hold meter probes on the battery terminals, making sure polarity is correct! Voltage should drop immediately, and then start to slowly but steadily rise after after a few seconds. No change with a flat battery indicates battery failure. Replace battery.
3. If both charger and battery are good, then problem is with camera. There are no user serviceable parts inside the camera, and as with laptop computers, it will probably be more economical to buy a new product, and take advantage of the always cheaper prices of newer and better models.
Jul 04, 2008 | Fuji Cameras
Neewer Mini 12V/24V LED Display Digital Car Volt Meter Vehicle Voltage G Logo
65 people viewed this question
Top Neewer Home Security Experts
Lawrence Oravetz
Are you a Neewer Home Security Expert? Answer questions, earn points and help others
