Question about Oreck Touch Bagless Upright Vacuum, BU10010
When i turn on the vaccum, i hear a high pitched sound.
The vaccum sounds like it is plugged but the canister is empty. what is the matter
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
Aquamate is making a high pitch sound and the brush isn't moving
Check the belt and brush roller on your Aquamate. The belt may have slipped or be broken. There also may be a build up of hair or fibers stopping up the brush and preventing it from turning.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Apr 04, 2014 | Rainbow Rexair Brush, Aquamate R2262
Hi, i just bought a Dyson DC 22 yesterday and it makes this really annoying high pitched noise? Is thia normal? Or should i take it back to the supplier?
Sorry to hear you're having difficulties your DC22. So we can identify the cause of the high-pitched noise you're hearing, and recommend the best course of action, I'd suggest calling us directly so one of our experts can diagnose any issues over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 01, 2011 | Dyson DC22 Motorhead Canister Vacuum...
Light keeps flashing on top of canister of my Hoover Wind Tunnel but I emptied and cleaned it well. It sounds right when I turn it on then it goes into this sound like something is stuck but there...
sounds like a possible plug ,then when you first start it up the plug gets stuck a gain.
try taking hose off the unit and running water through hose .if water flows good ,check and see if lid is secure when closed.
Jul 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Dyson Vaccum suction not strong enough
Look for an obstruction in the air passages at the bottom and where the air enters the canister. Make sure the HEPA filter is not plugged (take it out for a test). Hope this helps!
Mar 05, 2010 | Vacuums
High pitch whirr
when you remove the canister to empty it there is a filter on the bottom that can be removed and cleaned or replaced check to see if there is also one on the top.
Apr 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Overfull bag caused shutdown-will not restart
There can be quite a number of causes for these problems. A lot of the time there is a clog that the consumer has not found. If the motor sounds like it is running at a high pitched noise, and there is low or no suction, then that's your problem.
With the over full bag problem, I might have to know a little more information. There may be a reset button on the machine. You are going to want to check around the base of the machine where the brush roll is. Also, a good thing to do is to just change the bag and give the machine about 15 minutes before you turn it back on. It's high unlikely that you shorted-out the thermal protector with one time of not changing the bag.
Oct 02, 2007 | GE 106766 Bagged Canister Vacuum
Oreck Touch Bagless Upright Vacuum, BU10010 Logo
44 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
