Question about Mitsubishi Televison & Video
How to set the time on mod.HS-U34(C).
Cannot set the clock.
2 Suggested Answers
  • 18 Answers
SOURCE: I cannot find my instruction book for my video
Unless it says DVR you can't use a DVD player to record.
Posted on Sep 08, 2009
There doesn't seem to be a separate clock battery, how does canon sx50 hs power the clock?
From the main batteries. If there truly is no separate battery then a capacitor holds enough power so the clock keeps running while you change the main batts.
Dec 26, 2016 | Canon PowerShot SX50 HS Digital Camera -...
How do I set the time?
There may have been an option in the set up procedure for manual vs. automatic time setting
Oct 18, 2015 | Mitsubishi HS-U510 VHS VCR
Ho to set Clock on GE Mod JRS068 J1BB
On GE ovens there should be a CLOCK button to press first. Then if the control has number pads 1 to 0 you enter the correct time and press clock or start again to finish. If it has no 1 to 0 pads there should be 2 arrow type buttons with + on one and - on the other. Press clock and then use + to go up or - to go down. Holding either button in will make it change fast. When you get close to correct time hit button slowly to finish. Hit clock button when time is correct.
Mar 09, 2015 | GE Ovens
The digital time and the analog do not match. How can I adjust the time so that the digital and analog will be the same.
You don't say what make of watch you have but working on the assumption that most watches are very similar, try the method used by Casio.
Press the mode button (at 8 O'clock?) to step through the setting program until the display says "HS".
Now press the 2 or 4 O'clock buttons to advance or ****** the hands until the correct time is shown.
Press the mode button until you return to the normal time keeping mode.
Jun 12, 2011 | Watches
Canon PowerShot SD4000 IS - How do I set the time for a 12-hour clock instead of a 24-hour clock?
I found that there is no specific way to switch it to 12 hour time vs. 24 hour military time.
Just found the instructions for setting the time from the menu.
Dec 26, 2010 | Canon SD4000 IS IXUS 300 HS Digital Camera
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
Xbox error code 16
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
Nov 27, 2007 | Microsoft Xbox Console
How to set the clock
Check here for a similiar model: http://download.jazel.net/misc/filecache/3f/3fca776cb32a0a5f4402168c2ef88bbe_1071-ManualHSU448.pdf You have the remote box? Most functions, clock/date set, channel add/delete and so on are done with the remote, and cannot be so done with the limited buttons on the VCR itself. Early VCRS (pre-90s) were setup with these VCR located buttons.
Aug 25, 2007 | Mitsubishi HS-U446 VCR
Televison & Video Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
