Question about Dryers
Ge adora dryer runs for 3 minutes and shuts off
Ge adora dryer runs for 3 minutes and shuts doff
  • 148 Answers
Could be thermal fuse.... or control dial DW
Posted on May 13, 2014
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: ge adora electric dryer dhvh52ef0ww
Easy fix. Get some windex or 409 cleaner and find the 2 metal stripe inside and wash hell out of em. They get a buildup on then that forms a moister barrier. The crappytronics cannot sense dampness and think the dang clothes is clean.
Posted on Jul 07, 2012
TheMobilian
  • 8220 Answers
SOURCE: GE dryer dcvh680ej0ms runs 3 minutes and shuts off and resets time
On esimple thing to try is clean the dryer moisture sensing bars inside the dryer. Wet clothes rub against these bars and tell the control the clothes is still damp. IF no moisture is detected then she shuts down. So what goes wrong? Dryer sheets have a waxy buildup on them which tends to coat the bars. Moisture cannot penetrate the barrier and therefore the control thinks all is kosher and shuts down. Energy saver feature don't ya know. LOL Rocket scientists no longer have a space shuttle program so they engineering dryers now. LOL
Houston we have a problem.
Posted on Aug 04, 2012
  • 2365 Answers
SOURCE: ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Posted on Mar 23, 2013
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
Dryer stops, restarts minutes later
It seems like clogged vent problem but as I always say The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary and
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | General Electric Dryers
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Be blessed.
Mar 22, 2013 | Dryers
I need a picture of the control board for a ge adora dryer
You have to program you new board. I think you enter into the t01 mode and then select the number that corresponds to your model dryer. Here is a link for the manual that shows steps to replacing the control board.
http://www.applianceblog.com/manuals/31-9136_GEFDryer.pdf
Dec 05, 2012 | Dryers
Ge adora electric dryer dhvh52ef0ww
Jul 07, 2012 | GE DHDVH52GFWW Gas Dryer
My GE Adora dryer is ripping clothes
look inside the drum with a flashlight and look for broken or loose tumbler rib, can be fixed with epoxy, sand smooth surfaces first, let cure and use appliance paint to paint it
Jun 09, 2012 | GE Adora Super Capacity Dryer
Ge adora gas dryer works fine for the first 8 minutes then will not ignite. hear a fluttering noise before the igniter glows. feel the problem might be the igniter coils
most likely you have bad gas coils.when the coils are on there way out they work fine until they heat up then they fail.the coils are what opens the gas valve,they are located on top of the gas valve,remove the 2 phillips screws,remove the cover and change out the coils.simple job
May 17, 2010 | GE DHDVH52GFWW Gas Dryer
Defrost
That's very unusual and not normal behavior of a refrigerator. - compressor should not be off for that long - Have you tried unplugging the refrigerator for a few minutes and plugging it back in ? If this problem is persistent you should have it serviced and have them check the defrost timer/control board
Aug 16, 2009 | GE Adora DSS25KSTSS Stainless Steel Side...
Dryers Logo
113 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
