Question about Generic Taski 8500 600 Bora / Baby Bora Vacuum Cleaner Bags, 10 Pk
Baby bora won't turn on
When plugged in it won't power up, the bag is new, and I dont see any loose connections
Vacuum won't turn on
change the switch this is very common the switches go out and that is the only thing wrong with it causing it not to get power
Mar 20, 2014 | Generic Taski 8500 600 Bora / Baby Bora...
check the windings if they are not broke replace the switch for it is broken
Took apart removed belt plugged in turned on power motor shaft will not spin
Check the electrical connections to the motor and make sure they didn't come loose. Also most people don't know the motor shaft can become dirty and needs to be clean and shinny. Clean with steel wool.
Nov 22, 2013 | Oreck XL2200 Bagged Upright Vacuum
Power can't be turn on
could be a bad plug end you can cut it off attach new plug. If that dont work new rewind or bad electronic board
Oct 27, 2013 | Miele S251i Plus Bagged Canister Vacuum
Hoover steam vac model f5912-900 stoppped sucking.please dont tell me to check the hose, there isnt one,and the extraction tank IS empty.this machine is brand new with 10 minutes on it ?????
There is a hose under or behind the extractor tank which can come loose or tear. Lower the handle and remove the tank to look for it. See if it sucks when you use the upholstery attachment. If it does this would indicate that the part that lowers to the floor is not going low enough to get the water.
Aug 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover c1810 bagged upright - power keeps cutting out - is there a reset button?
there might be a reset button on there but its not meant for continuous use. we need to figure out the problem why the power cuts out. what condition is the cord in? cuts nicks. also check the prongs on the plug. if not that could be a bad switch but it sounds like a loose connection
Jan 02, 2010 | Hoover Commerical Conquest C1810 Bagged...
Vacuum is not turning on
Try a ruling out a couple of things first before opening up the handle:
1) First lets make sure your outlet has power
a) can you plug anything else in and have it work?
b) is the vacuum plugged into a non-switched outlet?
c) will the vacuum work from a different outlet - in a different room?
2) Check the plug. Are the prongs loose? If so, you'll need to cut the
plug off, splice back the two wires (Black and White), then connect
to a new plug. You can get a new plug for $1-2.00 at any hardware
store.
3) Time to open up the handle:
a) sometimes the wires connected to the switch can become loose
and fall off. if that is the case just reconnect by plugging them
back onto the switch. You may also consider using pliers to
compress the connector onto the switch terminal.
Hope this helps!
Jul 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Brush is not turning
You may not have power to the power head. Check the plug at the neck of the power head, also the wand connections to make sure they aren't burnt. Most of these powerheads also have a circuit breaker on the top of it, press it to see if it will re-set. At the end of the hose handle, there is a female plug where the wand plugs into, push it ans see if it will move inward or not. If it does, then it has broken loose inside of the handle and isn't allowing a connection to the wand. The switch on the hose handle may be bad. The power head motor could be bad. These are the most common problems when the power head won't run.
Jan 26, 2009 | Kenmore 22812 Bagged Canister Vacuum
Generic Taski 8500 600 Bora / Baby Bora Vacuum Cleaner Bags, 10 Pk Logo
14 people viewed this question
Top Generic Vacuums Experts
JoeVacs
Are you a Generic Vacuum Expert? Answer questions, earn points and help others
