Question about Cobra 29 LTD CB Radio
How do i adjust the knobs? I am not sure where everything should be set. the radio used to work and i think my kids may have moved some stuff around
  • 98 Answers
Set everything at half mast.
Posted on Jun 16, 2009
When i try to calibrate my cobra 29 ltd classic the needle will not go to the right
make sure you have your radio set on CAL and then adjust the knob that says adjust .Turn it all the to the right then bring it back to the set point on the dial then un key the mic,move the switch to SWR , key the mic and that is your reading. Do this on channels 40 - 1 then 19. Make sure you write down the readings for each channel. The adjust your antenna from there.
Jul 05, 2014 | Cobra 29 LTD CB Radio
How to figure out settings and swr on a galaxy dx44
whats to figure out? You set the radio on channel 1 adjust the knob to read for check then adjust to set then move knob to swr and write down your reading.Do the same thing on channel 40 and 19 always writing down your reading.
Dec 28, 2012 | Galaxy Radios DX-949 40-Channels Base CB...
I have new cobra ltd new antannas and mounts can hear but cant talk
You say antennas,I assume co-phased,as long as they were installed correctly&adjusted for the lowest swr reading,we'll assume they are ok.Next step would be the radio adjustments ,there is a switch next to your meter that must be set to s/rf,another switch for cb/pa needs to be on cb and last the knob for mic gain needs to be set at about halfway to three quarters depending your voice level and mic type used..are you using the stock mic that came with the radio,if so you should be able to transmit..look at the meter when you key the mic and talk it should move with your voice.If your using an aftermarket mic such as a power mic,make sure the battery is fresh and the correct type,this may also not be wired correctly for your radio if bought second hand..next step would be taking vehicle w/radio to a reputable cb repair shop or technician to evaluate.Good luck and hope everything works out.
Sep 05, 2011 | Cobra 29 LTD CB Radio
Emerson rp 6247 radio AM stations does not come in clear
Try moving the telescopic antenna around in different directions until you get a clear reception. If that doesn't work, try moving the whole unit (radio) to another location. Make sure you are using the tuning knob to switch between stations. Moving it to a different location may be the best thing because the radio antenna may be received in frequency waves from another electronic device (i.e. a television set, another radio or in microwave) which is causing a reception to be poor.
Mar 21, 2011 | Emerson RP6247S FM/Weather/AM/TV Radio
My husband was given a used Brother Sewing Machine model VX950 but it didn't come with a manual. When he sets the stitch length and proceeds to sew the adjustment knob moves and will not maintain the...
You can get a user's manual and a service manual from this site - http://www.sewusa.com/Sewing_Machine_Manuals/Brother_Manuals/Brother_Service_Manuals/VX-940-950_Service_Manual.htm
The knob could be broken or just gunked up - try a hair dryer to soften up the years of lubrication and dust to see if the knob is moving because it cannot lock in at the length selected - like sliding on ice.
Feb 14, 2010 | Brother Sewing Machines
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
All static when not sending
There is a "squelch" control (may be a ring around the volume knob) that controls whether the radio thinks there is a signal to listen to. Adjust this until you don't hear the static (it should cut off all at once, that is where you want the control set).
Aug 16, 2009 | Cobra MicroTalk PR 1100 WX (15 Channels)...
The tuner knob on my SkyFi has gone rogue - when I turn it to try and get a station number, it goes to whatever number it pleases... any ideas?
Mine went south too, so leave the knob alone (tape it in place if you have to) and use a remote control for everything - thats what I did.
Aug 09, 2009 | Delphi SKYFi XM Radio Receiver
Pioneer super tuner 3
For most Pioneer single CD players, you can set the clock using the following steps:
1. Press and hold the SOURCE button until the unit turns off.
2.Press and hold the FUNCTION button, until display pops up, then release.
(If you do not have a FUNCTION button, then push the AUDIO button)
3. Press the FUNCTION button again until the clock shows on the display.
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6.Press the UP and DOWN to adjust minutes.
7. When complete, press the SOURCE button to exit.
  • 1 year ago
Apr 29, 2008 | Car Audio & Video
Lost instructions for sony cdx-gt11w car cd receiver
Press and hold the volume knob until the display shows clock adjust.
use the forward and rewind serch buttons (the small arrow buttons next to the volume nob) to switch hour and minute.
use the volume knob to adjust the time. When done press the volume knob to return to normal operation.
HTH
Apr 22, 2008 | Car Audio & Video
Cobra 29 LTD CB Radio Logo
394 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
