Question about Bravetti Platinum Pro 1 Quart Ice Cream Maker
ERROR CODE DEFICIENT ON A ICE MAKER PLATINUM
RED LIGHT FLASHING AND DISPLAY DEFICIENT
What is A1, A2 referring to on the machine display panel
If it is the lower display with the 2 green digits, then that is referring to hours of service since last brush clean cycle. It is just a timer. Once it reaches 99, it start to use letters and numbers, so A1 would be 101 hours since last brush clean. b1 would be 111 hours and so on. To clear this the machine must recognize a brush clean cycle. the next time you clean your freezer door, make sure the power switch is off. it will display a 5 minute timer and 4 temperature readings. All 4 of those temperature readings must be above 60 degrees Fahrenheit and remain above 60 for 5 minutes. If at any point the temps drop below 60, the timer will reset. The freezer door must remain off the machine during this time. Once the timer reaches 0, the machine will enter a Unit Cleaned state and you can reassemble the machine.
May 15, 2016 | Taylor Crown C713-27 Soft Serve Ice Cream...
Which ice cream flavor is better for kids?
If you are giving your child a good quality ice cream than it is safe and also delicious.
You can prefer flavors like:
a. Butter scotch
b. Vanilla
c. Strawberry
d. Mango
e. Orange, etc
Dec 25, 2015 | Ice Cream Makers
Just bought a waring pro snow cone maker and looking for just a manual to tell us how much ice etc...help
Go to: Snow Cone Maker Metallic Red and click on the Download link that says "Instruction Booklet" next to the little video display on the general bottom left corner of the page.
Jul 17, 2014 | Waring Pro - Snow Cone Maker - Metallic...
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
I need paddle/dasher for Rival Treat Shoppe ice creeam maker #8704.
There is a paddle listed as a replacement part at: http://www.rivalproducts.com/category.aspx?cid=1124
Oct 31, 2012 | Rival Treat Shoppe 4 Quart Ice...
We bought the display model from Wal-Mart and the gasket between the two canister havles is missing.
I had this same problem when I bought mine, except it wasn't a display model, as far as I know... I bought it on clearance, and when I opened the box and read the instructions I realized that I didn't have the replacement ring... I contacted Rival, and they were more than happy to send me one. That's what I would recommend! Hope this helps! :-)
Aug 11, 2010 | Rival GC9155 1.5 Quart Ice Cream Maker
Bravetti Platinum Pro 1 Quart Ice Cream Maker Logo
222 people viewed this question
Top Bravetti Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you a Bravetti Ice Cream Maker Expert? Answer questions, earn points and help others
