Question about Canon P23-DH Calculator
Clean printing keys on calculator - Canon P23-DH Calculator
Nothing happens when I press the zero key on my Canon P170-DH calculator
Probably dirty. I would take it apart and clean that key. You might take pictures to ensure that you can put it back together correctly.
Good luck,
Paul
Jul 30, 2016 | Canon P170-DH Printing Calculator
When i turn on calculator it will display but no keys will work. the (+, -, etc)
haas n e 1 dropped liquid on it? open it up and clean the contacts with isoproponol alcohol. or check power lead to number pad
May 19, 2015 | Canon MP11DX Two-Color Printing Desktop...
Casio ms-20nc set tax rate
Non-printing models MS-20NC (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models MS-20NC (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Apr 29, 2014 | Sharp EL-330AB Calculator
The tax rate is not at 10% . How can I change this??
How do I program tax rate into my calculator?
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
Printing models (except HR-8TE):
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
May 04, 2011 | Casio MS-10VC Calculator
Change tax rate
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
2. Press [CA]
5. Press [TAX+]
6. Press [SET/%]
Jan 04, 2011 | Casio MS-80TV Scientific Calculator
What is the difference between the VX2652H and the VX2652B?
The Sharp VX-2652H is a commercial calculator that prints in 2 colors, extra large display,Special features include 3-level (sub/total/grand) totaling, markup keys, tax keys, a 4-key memory and item count. AC operation. 2.75"H x 9.83"W x 12.5"D.
The Sharp VX-2652B is a scientific calculator,
Quick and quiet 12 digit print/display calculator with stored memory tax rate key and 4 key memory. Large, easy-to-read 12 mm display.Features .Comfortable Cylindrical Step-sculptured Keys . designed for fast and comfortable operation. Extra ease is provided by contoured Plus/Equal and Minus/Equal keys.
So the difference is 1 is a commercial calculator and the other is a scientific calculator.
Sep 07, 2010 | Sharp VX-2652B Calculator
Sticky calculater keys
First-take the batteries out. You should be able to take the case off from the back. Use a q-tip and alcohol. It will clean and dry immediately. Let dry a day to make sure there is no liquid in it before you put the batteries back in.
Dec 20, 2009 | Texas Instruments TI-89 Calculator
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
Toshiba printing caluclator
Hey Dan, try cleaning the rubber contact pads under the key button with a damp rag as well as the board it contacts with. Some machines have a carbon contact instead of a rubber one. Look closely and make sure the carbon is not scratched or worn off. If so, scrap it.
May 23, 2007 | Canon P23-DHV Calculator
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
Canon P23-DH Calculator Logo
old marine
old marine
