Question about Kitchen Ranges
How to adjust freeplay on the clutch of Toyota Runx RS 1400
The car do not have the pulling power on pulling away only after your speed is about 60km
  • 341 Answers
SOURCE: 2003 toyota mr2 spyder 5 speed transmission grinding noise
Here is what is going on. When you push in the clutch pedal you remove the connection between the engine and the transmission. At this time all the parts in the transmission stop rotating.Since the only parts in the transmission that can rotate without moving the car are the input parts we can safely assume that the noise can only be from there.This can be a transmission input bearing. Worn Synchro mechanism (allows the transmission to shift without grinding the gears)Low fluid in the tranny. Or a bad clutch component. Top off or change the fluid. If it still makes the noise you need to take it to a tranny shop.
Posted on Nov 30, 2008
yankstorm02
  • 145 Answers
SOURCE: CLUTCH ADJUSTMENT 1997 TOYOTA COEOLLA
This vehicle has a hydraulic clutch system check the fluid level in the clutch master cylinder it is located on the firewall near the brake master cylinder fill it if its low than check hydraulic system for leaks, possibly slave cylinder, you will have to rebleed the system if part replacement is neccassary
Posted on Apr 11, 2009
emissionwiz
  • 76691 Answers
SOURCE: DOES A 96 TOYOTA TACOMA CLUTCH HAVE AN ADJUSTMENT
it is a self adjusting hydraulic clutch, if the clutch is engaging high on the pedal the clutch is worn out.
Posted on Nov 02, 2009
Testimonial: "THAT WAS FAST THANKS "
  • 3 Answers
SOURCE: how do you adjust the clutch pedal freeplay in a
Dear micus 1979,
Just went through the slipping nightmare!
Here's the deal, check between the thermostat housing and the transmission where it connects to the engine block after you have let it warm up to operating temp. If you feel water then you have a leak in this housing that leaks water and antifreeze directly into the clutch area of the transmission. Btw, just in case, the thermostat housing is the black plastic part on the front right of the motor that connects to the radiator hose. If you can help it, DO NOT TAKE IT TO A MECHANIC! They wanted to charge me over $200 to replace what turned out to be a $50 part at O'Riely's and about 30min.s of work! Hose clamp pliers a real plus on this one! Yes folks, a $50 part can cause you to shell out up to about $1200 in clutch repair costs! Go FORD!
Posted on Apr 21, 2010
roniecon
  • 6826 Answers
SOURCE: Having problems with the clutch in my 1998 Ford
The clutch is not adjustable,it is a fluid clutch.It has to be a leak,or the slave cylinder,and,or, the master cylinder are bad,It does not have to be leaking to be bad,but it is one of the two.Rate please,thank you.
Posted on Jul 12, 2010
Testimonial: "Wow. I was not expecting an answer back. Not only was it helpful, but it was also quick. Thank you so much."
How to adjust the clutch on a 2003 sportster 883 custom
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with 1/2 inch wrench, loosen the jam
nut using a 9/16 inch wrench and back the jam nut away from the cable adjuster and then move the adjuster toward jam nut to introduce a large amount of free play at hand lever. THEN remove the locknut and bolt to free the left side footrest from the footrest support and then remove the footrest and spring washer and THEN using a T-27 TORX driver, remove the four TORX screws with washers to remove clutch inspection cover exercising caution to avoid damaging or dislodging the quad ring in the primary cover. THEN slide the spring with the attached hex lockplate from the flats of the adjusting screw. THEN turn the adjusting screw counterclockwise until resistance is felt THEN back off the adjusting screw 1/4 turn. THEN slide spring with hex lockplate onto the flats of the adjusting screw and if necessary, turn adjusting screw clockwise just slightly so that the lockplate slides onto the flats while also fitting within recess of the outer ramp. Replace the quad ring if it is very old, deteriorated or etc. and verify that quad ring is fully seated in the groove of the primary cover and a few well spaced drops of instant contact cement can be used to hold it in place. Using the T-27 TORX driver, install the TORX screws and washers to secure the clutch inspection cover in place and tighten the screws in a crosswise pattern to 84-108 in-lbs (9-12
Nm). THEN turn the cable adjuster clockwise away from the jam nut until all of the slack is eliminated. THEN pull the clutch cable ferrule at the hand control end of the clutch cable at the hand control lever bracket away from the clutch hand lever bracket to check the free play. You need to obtain 1/16 to 1/8 inch free play between the end of the cable ferrule and the clutch hand lever bracket i.e. while you are pulling the cable away from the clutch lever mechanism bracket there should be a space or freeplay of 1/16 to 1/8 inch or in other words if you can pull the clutch cable away from the clutch lever bracket that much you have the correct lever freeplay, so turn the cable adjuster as necessary to get this amount of freeplay between the end of the clutch cable and the clutch lever bracket on the handlebars. After you have adjusted the cable so that you have this freeplay then hold the adjuster with a 1/2 inch wrench and using a 9/16 inch wrench, tighten jam nut against cable adjuster and then pull the rubber cable adjuster cover over the cable adjuster mechanism. THEN place the spring washer over the lower inside hole of the left footrest support with the concave side of the spring washer facing the support flange. THEN align the holes in the footrest with the threaded holes in the support and spring washer and install the bolt and locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm).
Aug 06, 2014 | Motorcycles
How do i adjust my clutch on my 2003 1200c sportster
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with one half inch wrench, loosen the jam
Locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm).
Jul 11, 2014 | 2003 Harley Davidson XL 1200 C Sportster...
Clutch adjustment
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with 1/2 inch wrench, loosen the jam nut using a 9/16 inch wrench and back the jam nut away from the cable adjuster and then move the adjuster toward jam nut to introduce a large amount of free play at hand lever. THEN using a T-27 TORX driver, remove the five TORX screws with washers to remove clutch inspection cover (derby cover) and seal in the primary cover (unless it has a gasket as aftermarket or Screaming Eagle covers will have in which case remove the gasket). IF the screws are very tight use a spring loaded impact driver with the correct T-27 TORX bit and a suitable sized hammer to shock them loose OR heat them with a hot air gun (sometimes people also put loctite on the screw threads which then may need heat to break down this locking compound). THEN using an Allen key in, and to hold, the adjustment screw and a wrench on the locknut loosen the locknut and then turn the adjusting screw in or clockwise until resistance is felt (to take up all freeplay and lightly seat the adjuster to the clutch pushrod but no more) and then activate the clutch lever to ensure that the clutch release balls are seated in the ramps. THEN back off the adjusting screw one half to one full turn. THEN holding the Allen key and adjusting screw so neither can move anymore tighten the locknut to 72-120 in-lbs (8.1-13.6 Nm). THEN squeeze the clutch lever to maximum limit three times, to set the ball and ramp release mechanism. THEN replace the cover seal or gasket if it is very old, deteriorated or etc. and verify that the seal is fully seated in the groove of the cover and if there is a gasket make sure it is facing the correct way i.e. with the rubber sealing surface towards the primary cover and the triangulated screw hole to the top. THEN using the T-27 TORX driver, install the five TORX screws and washers to secure the clutch inspection cover in place and tighten the screws in a crosswise pattern to 84-108 in-lbs (9-12Nm). THEN move to the cable adjuster and turn the cable adjuster clockwise away from the jam nut until all of the slack is eliminated. THEN pull the clutch cable ferrule at the hand control end of the clutch cable at the hand control lever bracket away from the clutch hand lever bracket to check the free play. You need to obtain 1/16 to 1/8 inch free play between the end of the cable ferrule and the clutch hand lever bracket i.e. while you are pulling the cable away from the clutch lever mechanism bracket there should be a space or freeplay of 1/16 to 1/8 inch or in other words if you can pull the clutch cable away from the clutch lever bracket that much you have the correct lever freeplay, so turn the cable adjuster as necessary to get this amount of freeplay between the end of the clutch cable and the clutch lever bracket on the handlebars. After you have adjusted the cable so that you have this freeplay then hold the adjuster with a 1/2 inch wrench and using a 9/16 inch wrench, tighten jam nut against cable adjuster and then pull the rubber cable adjuster cover over the cable adjuster mechanism. THEN place the spring washer over the lower inside hole of the left footrest support with the concave side of the spring washer facing the support flange. THEN align the holes in the footrest with the threaded holes in the support and spring washer and install the bolt and Locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm). These cable adjuster instructions are for stock HD clutch cables as aftermarket cables will be somewhat different to adjust BUT the idea will be the same.
Jul 06, 2014 | Harley Davidson FLHRI Road King...
My clutch so how do i properly adjust the clutch on 07 h.d. xl 1200 sporty-youttube
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with 1/2 inch wrench, loosen the jam nut using a 9/16 inch wrench and back the jam nut away from the cable adjuster and then move the adjuster toward jam nut to introduce a large amount of free play at hand lever. THEN remove the locknut and bolt to free the left side footrest from the footrest support and then remove the footrest and spring washer and THEN using a T-27 TORX driver, remove the four TORX screws with washers to remove clutch inspection cover exercising caution to avoid damaging or dislodging the quad ring in the primary cover. THEN slide the spring with the attached hex lockplate from the flats of the adjusting screw. THEN turn the adjusting screw counterclockwise until resistance is felt THEN back off the adjusting screw 1/4 turn. THEN slide spring with hex lockplate onto the flats of the adjusting screw and if necessary, turn adjusting screw clockwise just slightly so that the lockplate slides onto the flats while also fitting within recess of the outer ramp. Replace the quad ring if it is very old, deteriorated or etc. and verify that quad ring is fully seated in the groove of the primary cover and a few well spaced drops of instant contact cement can be used to hold it in place. Using the T-27 TORX driver, install the TORX screws and washers to secure the clutch inspection cover in place and tighten the screws in a crosswise pattern to 84-108 in-lbs (9-12 Nm). THEN turn the cable adjuster clockwise away from the jam nut until all of the slack is eliminated. THEN pull the clutch cable ferrule at the hand control end of the clutch cable at the hand control lever bracket away from the clutch hand lever bracket to check the free play. You need to obtain 1/16 to 1/8 inch free play between the end of the cable ferrule and the clutch hand lever bracket i.e. while you are pulling the cable away from the clutch lever mechanism bracket there should be a space or freeplay of 1/16 to 1/8 inch or in other words if you can pull the clutch cable away from the clutch lever bracket that much you have the correct lever freeplay, so turn the cable adjuster as necessary to get this amount of freeplay between the end of the clutch cable and the clutch lever bracket on the handlebars. After you have adjusted the cable so that you have this freeplay then hold the adjuster with a 1/2 inch wrench and using a 9/16 inch wrench, tighten jam nut against cable adjuster and then pull the rubber cable adjuster cover over the cable adjuster mechanism. THEN place the spring washer over the lower inside hole of the left footrest support with the concave side of the spring washer facing the support flange. THEN align the holes in the footrest with the threaded holes in the support and spring washer and install the bolt and Locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm).
Jun 28, 2014 | 2000 Harley Davidson XL 1200 C Sportster...
How do i ajust the clutch ?
Jun 20, 2014 | 2002 Harley Davidson FLHR - FLHRCI Road...
Clutch sliping on 1990 dr250s, how can I adjust it?
NOT SURE EXACTLY WHAT YOU MEAN ARE YOU ASSEMBLING ITOR TRYING TO ADJUST IT. THERE IS NO ADJUSTMENT TO A CLUTCH ONLY FREEPLAY ADJUSTMENT.
Jun 03, 2013 | 1990 Suzuki DR 650 RS
I have a 1989 Toyota Pickup 22RE Engine 5 Speed Manual Transmission - The problem is that the clutch slips on higher gears especially on cruise control when I encounter a hill. Can you tell me if there is...
If it's a hydraulic operated clutch, as I think it is, then no, there is no adjustment. Only the cable operated clutches were adjustable. But there is a clutch pedal height and free-play adjustment that needs to be correct. Freeplay distance is 3/16 to 5/8 inch, adjusted at the pedal end of clutch pushrod. I don't know the pedal height for your pickup (you'll have to ask some toyota person), but the adjustment is made near top of pedal where it contacts the stopper bolt.
Nov 07, 2011 | 1989 Toyota Pickup SR5
How to adjust a clutch on a2005hd fatboy?
Take all the play off clutch lever using adjusting nuts under rubber boot on clutch cable remove derby cover on primary cover use allen wrench to hold push rod while loosing lock nut turn allen wrench clock wise on push rod until it just stops do not apply pressure you will bend push rod.then turn counter clock wise about half turn hold with allen wrench tighten lock nut . Adjust nuts on cable until; 1/8 inch play on clutch lever should be good to go .
Mar 23, 2011 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Can i adjust the clutch on a 1990 model toyota land criuser petrol ute
there are only two adjustment you can make on a hydraulic clutch set up and that is pedal hight and free play. To adjust pedal hight you rotate pedal stop bolt at top of pedal assembly to adjust the hight. To adjust freeplay you loosen the lock nut at the master cylinder pushrod and turn push rod in or out to the specified freeplay then you tighten everything back up
Feb 07, 2011 | 1990 Toyota Land Cruiser
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
