Question about Toshiba 32l4200u 32" 720p Led-lcd Tv - 16:9 - Hdtv
32L4200U Missing the cylinder on the base
Remote code for 32L4200U
The code, if applicable, will be in the remote.
Aug 16, 2016 | Toshiba Televison & Video
I noticed the abs fuse is missing on my 2001 chevy prizm base model. will i have abs if i replace the fuse? didn't abs come standard with the car?
You can follow the brake lines from the master cylinder to find out if your car has ABS. There will be a pump and controller if it does.
ABS was a $650 option.
Nov 18, 2015 | Cars & Trucks
Replaced the head and Im not getting spark, what could it be?
Check all your grounds very carefully. Newer cars are quite sensitive about grounding and one missing ground can throw the whole works off.
Sep 07, 2015 | 2007 Chrysler PT Cruiser Base
My 1996 Hyundai is only running on 3 cylinders how do I find out which cylinderits missing on?
I am curious, how do you know it's missing?
One way (safest way) is with a temperature read
er: with the engine running, aim the reader at each exhaust port. The missing cylinder will be colder than the others.
Another old-school way: (electrical shock hazard) with the engine running, pull the plug wire of each cylinder, either at the plug end or the other end, one at a time. The missing cylinder will be revealed when there is no change in the engine's sound.
Nov 19, 2014 | Hyundai Cars & Trucks
Can I turn on a Toshiba 32L4200U without the remote?
Yes! As you face the TV screen on the left hand side panel, the top button is the power button.......it will either turn on or to standby......if it goes to standby press one of the next 2 buttons which are the channel up and down buttons!
Oct 23, 2014 | Toshiba 32L4200U - 32in Class 31.5in...
How do i change the the antenna from cable to antenna
which of these TVs is yours?
Originally supplied with models: 19AV600U, 19C100U, 19SL400U, 22AV500U, 22AV600U, 22C100U, 22SL400U, 26AV500U, 26AV502R, 26AV502R/U, 26AV502RZ, 26AV502U, 26AV52R, 26AV52U, 26C100U, 26C100U1, 26c1100u, 26SL400U, 32AV500U, 32AV502R, 32AV502RZ, 32AV502U, 32AV50SU, 32AV52R, 32C100U, 32C100U1, 32C100U2, 32CV510, 32CV510U, 32DT1U, 32E200U, 32RV530U, 32SL400U, 37AV500E, 37av500u, 37AV502R, 37AV502U, 37AV52R, 37AV52U, 37CV510, 37CV510U, 37E200U, 37RV525R, 37RV525RZ, 37RV52R, 37RV530U, 40E200U, 40E200U1, 40E200U2, 40FT1U, 40G300U, 40G30U, 40RV525R, 40RV525U, 40RV52R, 40RV52U, 40XF550U, 40XV640U, 40XV645U, 40XV648U, 42AV500U, 42RV530, 42RV530U, 42RV535U, 46/40/55S41U, 46G300U, 46G30U, 46RV525R, 46RV525U, 46RV530U, 46RV535U, 46RV53CU, 46SL412U, 46XF550U, 46XV640U, 46XV645U, 46XV648U, 52RV, 52RV530U, 52RV535U, 52RV53U, 52XF550U, 52XV645U, 52XV648U, 55G300U, 55HT1U, 55S41U, 55SL412U, 19AV600UZ, 19SL410U, 24SL410U, 32C110UM, 32FT2U, 32SL415UM, 40E210U, 40SL412U, 55G310U, 42RV525R, 32C100UM, 32DT2U, 40E210U1, 65HT2U, 32RV525RZ, 46RV525RM, 40G300U3, 46G300U1, 32C120U, CT90302 Programming Instructions and Codes, CT90302, 75022871, 75017678, 32E20U, 37E20U, 40E20U, CT90325, 75028874, 24SL410UM, 32C110U, 32SL410U, 32SL410UM, 40E210UM, 46G310U, 32C110U1, 32DT2U1, 40FT2U, 32C10U, 19L4200U, 24L4200U, 32L4200U, 40L5200U, 46L5200U, 50L5200U, 26C100UM, 40E200UM, 55HT1, 50L2200U, 39L1350UC
Jan 12, 2013 | Toshiba Ct90325 Remote Control
My 2004 Kia Rio w/161,000 miles is missing on the #1 and 4 cylinders. I've had the ignition coil, spark plugs, spark plug wires replaced, yet the problem persists. Sometimes, the car runs good for a f
The car computer does the firing of the spark plugs based on info provided to it by various sensors in car. Your mechanic is spot on. Ouch!
Jun 20, 2017 | 2004 Kia Rio
I feel like I'm missing something. I can not attach the handlebars to the bike. I have one long screw, a bolt and some small black cylinder cut on an angle. The instructions are not helpful because...
the cylinder cut on an angle is what the long bolt should bolt to, put the cylinder below the handle bars, and drop the long nut down through the handle bars and into the cylinder, ( the hole in it should be threaded,) only start the bolt so it hangs onto the cylinder, then feed that into the top of the neck hole, where the handle bars slide into,, once the desired height is ok,, tighten that bolt, the cylinder will come up at an angle and tighten the neck and handle bars !! Good Luck
Jul 02, 2011 | Dynacraft Girls 16" Barbie Bike
Need sequence to blrrd brakes 02 dakota
Dakota, 2001-2005
Bleeding the Brake System
Brake fluid tends to darken over time. This does not necessarily indicate contamination. Examine fluid closely for foreign matter.
The primary and secondary hydraulic brake systems are separate and are bled independently. During the bleeding operation, do not allow the reservoir to run dry. Keep the master cylinder reservoir filled with brake fluid. Never use brake fluid that has been drained from the hydraulic system, no matter how clean it seems.
  1. Clean all dirt from around the master cylinder fill cap, remove the cap and fill the master cylinder with brake fluid until the level is within 1 / 4 in. (6mm) of the top edge of the reservoir.
  2. Clean the bleeder screws at all 4 wheels. The bleeder screws are located on the back of the brake backing plate (drum brakes) and on the top of the brake calipers (disc brakes).
  3. Bleeder screws should be protected with rubber caps. If they are missing, the orifice may easily become clogged with road dirt. If the screw refuses to bleed when loosened, remove it and blow clear. Aftermarket caps are readily available.
Bleeding the ABS System
This is accomplished using the same methods as for the base brake system. Refer to those procedures.
ABS system bleeding requires conventional bleeding methods plus use of the DRB scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
  1. Perform base brake bleeding. Refer to the appropriate section.
  2. Connect the scan tool to the data link connector beneath the dashboard.
  3. Select "Antilock Brakes" followed by "Miscellaneous", then "Bleed Brakes". Follow the instructions displayed until the unit displays "Test Complete", then disconnect the scan tool and proceed.
  4. Perform a base brake bleeding a second time.
  5. Top up the master cylinder.
Hope helps (remember rated and comment this).
Aug 26, 2010 | 2002 Dodge Dakota Club Cab
Rough idle and missing during acceleration
you could have clogged fuel injectors or fuel filter.
Apr 27, 2009 | 2001 Mazda Tribute
Toshiba 32l4200u 32" 720p Led-lcd Tv - 16:9 - Hdtv Logo
13 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
