Question about Zodiac ZO2308 Watch
Zodiac watch changed battery
Wont work
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
I have a zodiac 1882 what type of battery does it need?
It's a 395 (SR 927 SW), however you're going to need a case wrench and a 4-pin vise to get the back off so you're looking at a minimum of $40 for the battery and the tools and that's if you know where to look. The other problem is the rubber gasket which may need to be replaced as well. Unless you happen to have a supply of them handy for that exact size case, your watch will no longer be water resistant to the manufacturers specifications. You could probably wash your hands with it but I wouldn't recommend anything more intense. The problem that you have is that you won't know if you need a new gasket until you get the case open and as noted, that's cost you a minimum of $40 to find out and you get the pleasure of having a set of tools that you'll probably never use again. Or, you could save yourself the money, headache and aggravation and of course the high probability of you damaging it because you lack the experience to change the battery on a screw-back, water resistant timepiece and just take it to a local jeweler, pay $10 - $15 to professionals who know what they are doing and will include the replacing of the gasket at no extra charge.
A universal Screw-Back (what your watch has) Watch and a Case Wrench captainhawk1_18.jpg
Jun 23, 2011 | Zodiac "Sea Dragon" Watch
My Sea Dragon watch has stopped. I've tried winding the stem in the closed position until I'm blue in the face, but it won't re-start. Any tips?
All of the models I looked at are quartz types (which are battery driven).
This would account for the failure to wind it up.
You can have a new battery fitted at your local watch shop.
Dec 22, 2010 | Zodiac "Sea Dragon" Watch
Where can i buy a replacement watch band for my Zodiac sea dragon watch?
you can go to the cherry hill mall if you live in New Jersey. Its a place for watches, and ask the man if he sells bands for watches. He'll say no but he can order one for you
Feb 28, 2010 | Zodiac "Sea Dragon" Watch
I have sent a Zodiac watch to Switzerland and the estimate has come back with a complete revision.is this a service as i have never heard of this before
If the watch parts are out of production (Generally speaking manufacturers only keep enough parts to make repairs for about 5 years) a revision is another way of saying the workings of the watch will be replaced but not with the same parts it came with. This is usually a modification to accommodate a new movement.
Sep 17, 2009 | Zodiac Watches
Replace mineral crystal in Zodiac Sea Dragon ZO-2201
Its better you bring your watch to a service center ,Because equipped of all the tools.
Hope it may helps;
Jun 16, 2009 | Zodiac "Sea Dragon" Watch
How do I close the stem on a zodiac watch?
Your watch do not have screw down crown feature. You can only pull out or push in that crown.
Check instructions for yourself from the official Zodiac document here:
https://www.zodiacwatches.com/images/pdf/zodiac_watchinstructions.pdf
Rate me, please.
Mar 14, 2009 | Zodiac "Sea Dragon" Watch
Getting date on watch
udjust the date until the last date of month and surely the month will chagne thank you !
Aug 12, 2008 | Bulova Watch
Zodiac ZO2308 Watch Logo
16 people viewed this question
Top Zodiac Watches Experts
Ankit Chandel
Ankit Chandel
ray gallant
Are you a Zodiac Watch Expert? Answer questions, earn points and help others
