Question about Nikon COOLPIX L6 Compact Digital Camera 6MP 3X Optical Zoom w/2.5 inch LCD
Removing battery how to get the battery door open
    Guru:
  • Nikon Expert
  • 362 Answers
The battery door is on the bottom of the camera. Hold the camera bottom up with the battery door to your right. Slide the oval spring-loaded battery latch all the way to the right and gently pull up on the battery door.
Posted on Aug 26, 2014
How do i remove the battery.
Why not hand it to the people at the dealers
parts counter & have them show you?
Apr 23, 2014 | 2010 Dodge Journey RT
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
2000 ford taurus door open light won't shut off drains the battery
Spray W-D40 into the door latch. Should work since same thing happened to me.
Nov 29, 2009 | 2000 Ford Taurus
2000 Ford Taurus Battery Drain - - After the car door is opened the wipers still work, power windows still work, power seats still work, radio still works, etc. Shouldn't the battery power disengage to...
using a test light with all doors closed everything in the car off; disconnect your black battery cable then: connect a test light between the battery post you just removed the cable from and the cable you removed; the light should light. this is your short (leak) then remove fuses until you find the fuse that causes the light to go off your problem is in that circuit.
Nov 20, 2009 | 2003 Ford Taurus
Unable to open my Battery Door Satellite 1800-S274. I didnt want to use tools to pry open if unnecessary. Is there a trick to opening the door/cover? Thanks
The battery can be removed from Laptop by pulling the battery out after sliding the sliding buttons given near battery. you don't have to use any tool to remove battery out of the laptop.
Nov 18, 2009 | Computers & Internet
Unable to open doors
remove battery caple and open the door manulay
then fix the battery back
Nov 08, 2009 | 2000 Mazda Millenia
Car door opener not working..where is the battery? Is there one?
The remote does have a battery. It either has a small door that slides open or you remove a screw to separate the two halves of the case. The battery is inside.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
The Battery Door on my Sony Cybershot DSC-S40 won't open.
No easy solution except:
1. Remove all 3 screws from body.
2. Carefully wedge off the back half of body.
3. The back half is connected to the front half by a small cable. Don't break this!
4. The door has a hinge pin. Wedge up and remove this pin.
5. With small screwdriver, wedge off the door from top. Should pop out.
6. Apply small amount of oil on sliding areas.
7. Reinsert door. If still stuck, see step 5.
8. Reassemble camera back and screw down.
9. The reason for sticking is unknown, but door can still be removed by popping off as in step 5.
Nov 08, 2008 | Cameras
The date and time will not save on my canon powershot a560 when it is turned off and on.
Open your battery door. Notice inside that there's a little slide door inside labeled CR1220. Pry open this little slide door and remove and reinsert the encased watch battery (this battery powers the camera's clock). Removing and reinserting might fix it temporarily, but more than likely this battery is getting very low. Recommend going to your local drugstore's battery section and buying a replacement CR1220 battery. They're very common and inexpensive (a few bucks).
Sep 01, 2008 | Cameras
Canon A75 Battery door
Never did it on an S1, but on other models it required removing the back face of the camera to access the battery doory hinge pin.
Examine your camera, and if this sounds feasible, remove all screws along the perimeter of the camera (keeping track of their sizes and where they came from, write it down with a crude drawing of their locations/sizes). Also look for screws in the battery compartment, and any visible screws behind flaps/doors. Once all perimeter screws are removed, you should be able to remove the back face of the camera by prying it open from the bottom. Once opened, the pin holding the battery door should be able to be slid out, enabling removal of the old door. Then in reverse slide the pin into the new door, and reassemble the camera and its screws.
May 06, 2008 | Canon PowerShot S1 IS Digital Camera
Nikon COOLPIX L6 Compact Digital Camera 6MP 3X Optical Zoom w/2.5 inch LCD Logo
46 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
