Question about Royal 160MX Shredder
The power light won't stay on, we have to hold the power button to shred, is there any troubleshooting for this problem?
It won't stay on.
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Cant calibrate tony hawk shred board to my wii. I've tried everything
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
Jan 01, 2011 | Activision Tony Hawk Ride for Nintendo Wii
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Royal 160MX Shredder Logo
48 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
