Question about NoiseHush N450 Bluetooth Headset
I CANNOT HEAR THROUGH MY NOISEHUSH N450
I CANNONT HERAR THROUGH MY NOISEHUSH N450
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
Emachines n450 wlan drivers
Hi Arnold,
I am sure if you are looking to buy it there are several websites from where you can. i found one which is this http://www.notebookcheck.net/Intel-Atom-N450-Notebook-Processor.23722.0.html
hope this helps.
Aug 07, 2013 | Computers & Internet
Wifi driver for emachines n450
I think this is what you need. I think although it says N350 it uses the Atom N450 processor. The machine could have either the Atheros or the Broadcom wi-fi card so you need the correct one for it to work properly. There's a link on the page for a little program that detects what hardware is in the machine so you get the correct drivers for it here:
Hardware Detector
Drivers.
Jan 31, 2012 | Acer Computers & Internet
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 | Cell Phones
I cant herar when I talk with my friend with the skype. I tested my headphones. they are ok. What is the problem in my skype?
you most likely checked all the obvious settings, checked, volume control, within Skype it is not on mute.
also within Skype, you can also perform audio and video testing, to confirm the issue is not from your end.
If this still fails, and you can not hear the other party ... the issue may be at their end. They will need to check their settings and skype settings.
Oct 13, 2010 | Microsoft Windows XP Professional With...
How do i sharpen the plate on my commercial nutrifaster N450
The Nutrifaster blades do have to be sharpened every so often. You can send the blade into Nutrifaster and they will sharpen the blade for you. Go to Nutrifaster.com and look under spare parts.
Sep 22, 2009 | Nutrifaster N450 1056 Watts Juicer
I can herar water runnging inside the regierator.
You are probably hearing water running out of the unit during a defrost cycle. It runs inside a tube to the underneath of the refrigerator where it is collected in a pan and evaporated into the room by heat from the compressor fan.
Jun 28, 2009 | Whirlpool Refrigerators
Fuid inside compressor..do I undo drain plug !
Open the plug at the bottom of the tank while the compressor is on so that it will blow out all the crud. The black liquid is the gunk from the oil in the compressor and staknant water. When the crud stops coming out and you herar just air, you should close the valve and you are set to go. You should drain this tank al least once a month if you use the compressor a lot. I hope this helps. Don't forget to rate my answer. Thanks.
Feb 11, 2009 | Campbell Hausfeld 13 - Gallon Air...
NoiseHush N450 Bluetooth Headset Logo
22 people viewed this question
Top NoiseHush Radio Communications Experts
eradiostore
eradiostore
Are you a NoiseHush Radio Communication Expert? Answer questions, earn points and help others
