Question about Kitchen Ranges
GE range heats to 100 , or broil, but not to preset 350
Won't pre heat to 350 or 400
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Model Number?
Posted on May 01, 2014
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
the dr
  • 447 Answers
SOURCE: GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Posted on Nov 16, 2007
  • 213 Answers
SOURCE: ge oven...gas....not heating right
there is an ignitor bar that has to operate properly to open the gas saftey valve. the ignitor can glow but be weak so it wont open the gas valve. replace ignitor to slove problem
Posted on Nov 20, 2007
MNTECH
  • 1543 Answers
SOURCE: GE Spectra XL44 oes not heat to desired setting
The oven sensor ( WB21X5301) is suppose to tell the oven control when to turn on and off to reach and maintain oven temp, but before you go replacing it, try to observe how long it takes from the time you turn the oven on to the time the oven ignites. Ignition should be 30 seconds to about 90 seconds. If it is taking a very long time, replace the igniter (
WB2X9154
). Ignitors get weaker over time, and this should be looked at first, as both parts are not real cheap, so you don't want to just start throwing parts at it. Here is a trick you can try: On the JGBP90 (model you posted under) the broil ignitor is the same part number as the oven ignitor, so if the broiler, which is generally used much less than the oven, is working fine you can interchange the two ignitors to see if that solves your oven temp problem without having to buy a oven temp sensor first.
Posted on Nov 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
May 01, 2015 | Kenmore Kitchen Ranges
The stove doesn't heat up to the preset temperature. When I set it up to bake at 400 degrees, it goes up to 327 and stops heating further. The same occurs when I put it on broil.
If you preset to 450F what does the oven stop at?
Do you have an oven thermometer that you can use to compare against the reading (327F) that the oven gives you?
It appears to me that the oven thinks its hot enough to stop heating. Could be a temperature reading problem, a comparison error, a display error or a calibration error.
Is there another reboot process other than unplugging?
How old is the appliance?
Dec 26, 2014 | Kitchen Ranges
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
I have Range GE J34CFT 1 that is not heating up correctly
You have to start with putting an oven thermometer in the oven and comparing the oven temp with the temp that you set it to
Jul 21, 2009 | GE Kitchen Ranges
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Model. jtp35wom1ww serial.AR6 18302Q. Double Oven will not heat properly. Takes 40 minutes to heat to 350.
Check to see if Lower element is red after 5 minutes. if not you are just heating on the broil unit at 110 volts (1/4 of its full watts), may never get much hotter than 300 that way. if bake isn't red it may need to be replaced.
Jun 19, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
