Question about Haier RDE350AW Dryer
Impeller broke A PEICE OF PLASTIC CAME OUT OF DRYER VENT
How do i remove the wheels or whatever i need to remove to get the hose peice out it was held by a plastic peice tht i wanna replace
Remove the wheels, axle, handle latch and spring. Then try to find someone that still has a power head elbow for an old hoover. I can check to see if they still have any if you call me. 1-800-353-4677 tomorrow
Jan 29, 2014 | Vacuums
A loud clunking noise - the vent/filter check light came on plastic broken parts which looks like a fan or something.
Hi
Yes, your right, it is the blower fan for the dryer, something may have gotten down the filter element housing and broke it, or just from heat and time.
Yes, you can fix it if your somewhat mechanically inclined.
It is not a hard job, but must be done correctly.
I will send you a webpage with some parts choices.
I do not know where you location is so I cannot send you to the direct webpage.
Please rate me
Bud
parts webpage: http://www.ask.com/web?q=Miele+T9800++parts&qsrc=6&o=11145&l=dir
Youtube video on Miele dryer repair, not your model but will probably dissassemble the same way.
http://www.youtube.com/watch?v=Kl7jTH2d58A
Oct 26, 2012 | Miele T9800 Electric Dryer
The plastic cover that goes into the window broke. it connects to the hose that runs the hot air out the window. how or where can i find a replacement?
The vent termination is simulair to a dryer vent termination. Take the broken with you and visit any home center or hardware store, and I am sure you will be able to find an adequate replacement.
Apr 05, 2011 | Danby DPAC12031 Air Conditioner
Roper dryer res7646k replaced heater element , cleaned duct system & blower ,still not drying clothes on an 80 min. cycle. Checked vent outlet on dryer , good hot air coming out.
If you replaced the element then you are familiar with the "housing" where the impeller is located. Check to see if there is a significant amount of lint and/or debris around the impeller. I have found all kinds of debris around the impeller and the volume of air circulating can be significantly reduced.
Feb 11, 2011 | Roper Dryers
Pondmaster 1200gph pump stopped working. Inside
Sounds like the impeller broke.
Just remove the 4 phillips head screws to remove the housing, then pull the impeller out. When replacing the impeller be sure to have a good grip on it as the magnetic attraction will pull it in pretty hard.
The pump may still be under warranty, if so call the number on this web page: You can also order parts from them.
http://www.dannermfg.com/contact.asp
Jul 08, 2010 | Pondmaster PM 1200gph Mag Pump Plastic...
2005 dodge magnum
wring the wreckers and see if you can get a second hand one, even better if there is a self serve wreckers near you go there your self and remove the part you need
Oct 01, 2009 | 2005 Dodge Magnum
Kenmore Elite front load dryer
Probably a thermal fuse. You'll need a continuity meter to check it, though. Once you get one, unplug it. Remove the lower panel on the front. Beneath where the lint filter sits is your lint duct. Remove it (screws at top left and right and clip at botom center) Behind it is a white peice of plastic with 2 blue wires. Unplug them and check across the two prongs on the white thermal fuse to see if it is good. Replace if nessciary. If it is bad check your vent (dryer to wall and wall to outside) for restrictions or blockages.
Apr 21, 2008 | Kenmore 45081 Front Load Washer / Dryer
Sencing light on the dryer
The thermal fuse is the most common problem that can cause this. If you remove your bottom panel (2 1/4 inch screws) and then your lint duct (the area where your lint screen sits) you will see a white peice of plastic with 2 blue wires going to it behind the lint duct. That is your thermal fuse. A continuity meter can quickly be used to check to see if it is bad. If it is bad, replace it and re-install your lint duct then run you dryer on air dry (if you run it with heat, you could burn your replacment fuse out). Then go to the vent on the outside of your house. You should be able to feel a good deal of air pressure on your hand. If not, check the hose behind your dryer for kinks or being crushed (not uncommon even on "professional" instalations. If that is ok, you will need a cleaning for the house part of your vent.
Apr 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Haier RDE350AW Dryer Logo
22 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
