Question about Canon PowerShot A95 Digital Camera
Power wont turn on
Batteries are charged but it still wont power on
    New Friend:
If the camera will not power up then please check the following:
1. That the batteries are inserted correctly. Two should be facing upwards and two downwards. With the camera facing you (upside down) then the first battery on the left should have the positive terminal up, the second down, third up and last one down. If this does not work then ensure the slider switch to close the battery cover is fully closed - sometimes this sticks - as this closes a microswitch. If the camera still does not work then a fuse will have blown in the camera. This would be a very expensive repair. Hope this helps
Posted on May 23, 2014
How to Save my Laptop Battery?
Charge battery fully (with laptop off) then unplug AC power. Do not continuously have power plugged in. This will ruin your battery. Remove battery when not in use for long periods. To refresh battery charge fully then run laptop till it turns off. Turn on again and wait for it to turn off. When laptop wont turn on, charge battery fully again and repeat process about 3 times. This should extend an old battery's run time.
Oct 18, 2016 | Computers & Internet
Battery went on dead on my c3 yahama one night charged battery now turns over good but wont crank please help ! thanks
battery may be dead-it might charge up but wont hold enough power to turn bike over -buy new one
Oct 29, 2013 | 2007 Yamaha XT 660 R
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
My sl102 samsung wont turn on
Are you sure the battery is correctly charged?
Most USB connectors on most PC's don't deliver enough power to charge the battery. Try to charge the battery with the power cord till the green LED is on.
If you'r sure the battery is fully charged and the same happens again, remove the battery for a small time and put it in again.
Feb 20, 2013 | Samsung SL102 Digital Camera
My huawei mercury phone wont power on or charge
y wont my mercury turn on it wont even showet chargeing how can i fix the problem.
May 20, 2012 | Huawei M886 Mercury CDMA Cell Phone
Psp carge light wont come on and psp wont turn on
You either have a bad battery, or a bad power supply that charges the unit (power cord). If you have a friend that also has a PSP, try swapping out the battery to see if that works, and or try another power cord to see if the charging indicator light comes on. I think that possibly your battery is dead and the power cord might be bad. You can find good deals for both the battery and cord on ebay. Good luck!
Nov 07, 2009 | Sony PlayStation Portable (PSP) Console
Samsung Tocco Ultra wont charge or turn on.
you have probly blowed your battery (aka) a battery leak check your battery to see in you can squese it if you can then its leaked and you need to buy a new battery from amazon or somewhere else for about 5 pound plus P&P
Oct 17, 2009 | Samsung Tocco Ultra Cell Phone
1997 zx9 wont turn over battery dead
YOU NEED TO TRICKLE CHARGE THAT BATTERY TILL FULLY CHARGED AT A RATE OF 1 TO 2 AMPERS IF THE BATTERY WONT HOLD THE CHARGE YOU WILL NEED A NEW BATTERY THE NEW BATTERY WILL NEED TRICKLE CHARGING AT THE SAME AMPER RATING FOR AT LEAST 16 HOURS THE REASON WHY YOUR LIGHT WHENT OUT IS NOT ENOUGH POWER TO SUPPORT EVERY THING FROM THE BATTERY
Feb 02, 2009 | 2001 kawasaki ZX-9 R Ninja
Wont turn on
pull the battery and try to power on. if no good test the power adapter with a meter - should give 18-19 volts. if it boots with battery off, power up and put battery back on to charge.
hope this helps
Jan 17, 2009 | Acer TravelMate 6460 (LX.TED0Z.071) PC...
No power
If your battery become too dead the trickle charger wont recognize the battery so it wont charge it. However in that case you just need hook two batteries together to even the charge so it will recognize it. if your battery is truly charged then its a loose wire somewhere or bad switch.
Nov 10, 2008 | 1974 Laverda 1000 3C
Canon PowerShot A95 Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
