Question about HP Photosmart C6180 All-In-One InkJet Printer
I have a HP Photosmart C6180 all in one the error message displayed is ink system has failed it will not print appreciate any help
  • 100 Answers
The Ink System Failure messages on my C6180 were early symptoms that progressed continuous power cycling. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.I have a HP Photosmart C6180 all in one   - 74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these. here is a .
Posted on Sep 28, 2010
  • minpdx Jan 28, 2011
    This info has been so helpful along with this group of pictures:http://picasaweb.google.com/109215435720... The pictures show how to get to the logic board. Thank you for helping me fix my printer instead of turning it into a boat anchor!
Ink system failed???unable to print,copy,recieve faxes
Hello
Have a look at the link below, it should assist you in solving your problem.
http://h30434.www3.hp.com/t5/Other-printing-questions/Ink-system-failed-Error-Oxc18a0101-on-photosmart-D7160/m-p/14911
Nov 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 All-in-One printer that is 3 years old. It has been a great printer for our home. Today it decided it would no longer print and I get the following message: Ink System...
I had an ink system error message on my C6180 that evolved into the printer power cycling every 15 seconds of so. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Aug 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart c6180 all in one printer error message of 0xc19a0035, ink system has failed. unable to copy, receive faxes, or print. what can i do to fix it?
The "Ink System Failure" error is caused by air in the ink fed tubes. We have a step by step guide to perform a ink purge on the printer posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Following this procedure should get your printer back running in about 10 minutes.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a HP photosmart C6180 with Oxc19a0024
add andydragoescu on your y mess and y will try to help you!
Jun 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error message #Oxc19a0013----Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Solution
Wait two minutes.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
254 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
