Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
Sears progressive lid stuck
Lid to bag section stuck
How do you change the bag in a kenmore progressive true hepa canister vacuum?
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Vacuum wont run
THE BEST SOLUTION IS TO NEVER BUY A SEARS VACUUM AGAIN. THEY DO NOT LAST AND WARRANTY AND REPAIRS ARE TOO EXSPENSIVE! I BOUGHT THREE OVER TEH YEARS, AND NOW AS YOU KNOW, THREE STRIKES AND SEARS IS OUT!!!!!
Feb 24, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Lid won't close
You might have the vacuum bag in incorrectly. Pull your vacuum bag all the way out, and check the cardboard for arrows (as some bags are cut to go in one way, and one way only). If your vacuum has a cartridge that the vacuum bag goes into, make sure that this is seated completely, securely, and correctly. After you have checked all of this, seat your lid meaning make sure it is going to sit correctly on the housing, then as you are closing the lid, check the latch as it begins to close - making sure that the male and female portions are going to match up. You may have to give it a little pressure, but should not have to put enough pressure to break anything. Good luck.
Jan 21, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Power problem
With out checking it, it is hard to say, I think there is a reset, did you push it? But you do have a years warranty on this, that it into Sears for repair.
Apr 13, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
78 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
