Question about Intel Computers & Internet
I have intel dg35ec motherboard & intel p4 2.4 core 2 duo quad processor,2gb ram&360gb hdd. i need to run pinnacle studio 12 ultimate, can i need graphic card?which is suitable for this?
  • 157 Answers
This is a laptop?? If those specs are correct then the laptop will run pinnacle studio 12 ultimate beautifully without any modifications.
Posted on Jun 16, 2009
Hi guys, im using a intel dq35mp motherboard with a q6600 2.4ghz core 2 quad processor , with 8gb ddr2 ram (4x 2gb) and 4x 500gb hdd + 1x 1Tb hdd. im using a 5050watts power supply. i want to overcloc
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope it helps
Jun 30, 2012 | Intel Computers & Internet
I want to purchase nvidia professional card suggest me compatible graphic card for my intel dg35ec motherboard.
Nvidia Geforce GTX 560 is a very good choice but could be on the edge for the power-supply so to be sure spend some on a better power-supply!
Mar 23, 2012 | Intel DG35EC Motherboard
My DG41TX works perfectly with dual core processors, but with core 2 duo not, do 3 beeps and dont show any video, what i must do?? my core 2 duo is E8400 my dual core is E2180 Bios Version:...
The POST beep code - 3 short beeps mean RAM failure.
Try reseating the RAM modules.
If this does not solve your problem then remove all the RAM modules and insert one RAM module at a time into memory slot 0 (1st memory slot) to determine which is the faulty RAM module.
Jul 07, 2011 | Intel DG41TX Motherboard
When I was instoling pinnacle studio ustimate version 14, which I received when I bought camcord, it ask me that I don't have windo3.4. what can I do?
The system requirements for Pinnacle Studio Ultimate 14
1) Windows® 7, Windows Vista® (SP2), Windows XP (SP3) operating system.
2) Intel® Pentium® or AMD Athlon™ 1.8 GHz (2.4 GHz or higher recommended)
Intel Core™2 Duo 2.4 GHz required for AVCHD*, Intel Core™2 Quad 2.66 GHz or Intel Core i7 required for AVCHD* 1920.
3) 1 GB system memory recommended, 2 GB required for AVCHD*
4) A DirectX® 9 or 10 compatible graphics card with 64 MB (128 MB or higher recommended)
128 MB required for Red Giant Magic Bullet Looks Plug-in: Pixelshader 2 required, Intel GMA integrated graphics not supported. 256 MB required for HD and AVCHD*
5) DirectX 9 or higher compatible sound card.
6) 3,6 GB of free hard disk space.
7) DVD-ROM drive to install software.
Check to see if your system forfills the minimum system requirements.
Mar 07, 2011 | Pinnacle Studio Ultimate 14 for PC
Windows Not Showing & Not Supporting Actual RAM installed.
make sure that you don't need to overclock your setting (in BIOS ) so as to get full ddr3 frequency.That it, you need to overclock your CPU speed and if you want to work at great speed, try you upgrade you processor.
try a core 2 duo or a quad-core and make sure that it matches with your FSB, with maximum L catch ( 12 mb)
Jun 24, 2010 | Intel D845GVSR Motherboard
Earlier i had ASUS P5G-MX motherboard & 2.0 GHz Core 2 duo Processor.I upgrade my Motherboard to Asus P5KL-AM/PS & then i have a black screen with my 2.0 ghz processor, But i tried 2.8 ghz Core 2...
HI,
The only Thing To Do, is view both Motherboards, user Manuals.
To see The boards CPU Support List.
It could be to do with, certain Motherboards Supporting, certain CPUs.
I.e a 533mhz cpu, would not run on a Motherboard that supports 400mhz. The Systems Bios, May cause Other Problems.
If your getting a Black Screen, is it a possible Graphics/Ram Problem, Rather Than The CPU ??
Mike @ Compurepair.
Oct 22, 2009 | Intel Computers & Internet
Black Screen on Pinnacle Studio 12 when i preview a transition ?
I found with pinnacle 12 if you turn of the hardware acceleration and turn off the full-res preview,in video and audio preferences it speeds up transitions and text effects tremendously
Aug 14, 2009 | Pinnacle Studio Ultimate 12 for PC
My PC is very slow since I installed Pinnacle Studio 12 Ultimate
Check you startup programs and eleminat those you less likely need this will free up that slowness you are experiencing,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 10, 2009 | Pinnacle Studio Plus 12 for PC
ASUS P5L-VM 1394 mother
Here is a link to a website that identifies the specs for your motherboard, and also identifies the type of processors that are compatible with your motherboard. It is Intel Core 2 duo/ Intel Core 2 duo Extreme capable.
It looks like you have a good candidate for a gaming pc, in my opinion. I would suggest that you upgrade the memory to its max of 4 GB. This link also has a list of all compatible memory modules for your motherboard, If you click on a memory module, there is an option on the next page to tell you where you can buy it and for how much.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=32522&mfr=ASUS%2FASmobile&model=P5L&root=&LinkBack=&Sys=32522-ASUS%2FASmobile-P5L-VM+1394+Motherboard&distributor=0&submit1=Search
Apr 11, 2008 | ASUS P5E-VM DO Core 2 Quad Socket 775...
Computers & Internet Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
