Question about Briggs & Stratton LawnBoy 20Inch 65 HP Gas Powered Variable Speed Rear Wheel Drive Self Propelled Lawn Mower With Electric Start
Air filter replacement size part number
I need the air filter part number for the lawnboy model 10634 electric start
Lawnboy mower model 10743 will not start
When choke not on all the way coil willnot activate and throw spark ps carby should be cleaned out properly because fuel will off evaporated leaving oil guming up needle/seat
Jul 03, 2016 | Garden
Techumseh 195cc lawnboy runs fast then slow then stops
Replace spark plug and air filter.
May 27, 2013 | Garden
Briggs and Stratton
clogged fuel line. the choke restricts air flow if it runs fine choked it is probably getting too much air to run properly. those 2 seconds it is most likely running off a surplus of fuel from priming or something of that sort.
Check fuel lines and fuel filter for obstructions. I reccomend replacing fuel filter also. If this does not help is may be a fuel issue in the carburetor.
Feb 08, 2012 | Garden
I have an old lawnboy i need engine diagram
If you cant find one, I would suggest that you use a digital camera and take pictures during the disassembly. Then when you put it back together, just look at your pictures. Good luck...Lee
May 30, 2010 | Toro 89885 "lawnboy" Premium 4cycle Oil...
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
Can't find the filter to replace it in our Heil air conditioner
What is he model number of your Heil A/C. SOme are odd size filters. You can pick up washable filter at Walmart. The filter goes underneath the unit. Should be panel that slides off. I really need more info Thanks james
Jun 06, 2009 | Heating & Cooling
Briggs & Stratton LawnBoy 20Inch 65 HP Gas Powered Variable Speed Rear Wheel Drive Self Propelled Lawn Mower With Electric Start Logo
26 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
