Question about Electrolux Ergorapido Ultra EL1022A 2-in-1 Stick and Hand Vacuum Cleaner, 12 Volt Power, Motorized
Ergorapido ultra stick vac won't turn off unless it's put back into the charging base
I turn the vac on but it will not turn off unless I put it back in it's charger.
The hand held unit of my ergorapido works, however when in the stick the unit will not work, it seems to fire up then stops
check under neath to see if the bel is connected or it broke if its not sucking im not really sure how to answer that ive never had that happend it can be a wiring issue or switch it sounds like it can be the switch might need replacing the power or the pedal that unlocks it from the stick mode might be pinching somthing that stops it
Dec 05, 2014 | Electrolux EL1022A Ergorapido 2-in-1 Stick...
Why does my panasonic MCUG415 hose stop working after bag change?
The replacement bag may not be installed correctly or something in the suction path is being disturbed by the process (maybe a "bag full" detector). In an upright, there is a shutter that directs suction to the floor or the hose and it may be getting confused.
Apr 26, 2017 | Panasonic Mcug415 Upright Vacuum Cleaner
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
Won't turn on
Might be a fuse BUT it is enclosed in the unit. You would have to take it apart to see. IT could also be other parts in the power supply that have failed, With that in mind, if you do take it apart, take pictures so that you can put it back together.
Aug 27, 2012 | Sharper Image Ionic Breeze 3.0 Air...
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
How to open and clean oreck xl air purifier
You can download teh manual at
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Jul 08, 2010 | Oreck XL Professional Air Purifier
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Electrolux Ergorapido Ultra EL1022A 2-in-1 Stick and Hand Vacuum Cleaner, 12 Volt Power, Motorized Logo
Top Electrolux Air Purifiers Experts
Richard Lane
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
