Question about B&K Plumbing
HOW TO USE SELF CLOSING SHOWER VALVE 126-006LT
THERE ARE NO DIRECTIONS ON HOW THIS VALVE WORKS
My Moen shower will not turn off, the hot/cold turn valve is so tight I cannot turn off shower. Any suggestions for fixing this?
I think it needs maintenance. But this is a job you should leave to a tech. call plumber or goto the store who installed the valve.
Jan 06, 2015 | Moen & One Handle Tub & Shower Faucet
Could my shower be airlocked
No, the ball valve is likely rotated 180 degrees from where it should be. Shut off supply and verify the hols in the stainless ball are facing to the same side as the seals are.
Or the supply valves to the shower are still shut off.
There is a small possibility the pressure balancing valve is stuck closed.
Jan 15, 2012 | Delta & Single Handle Shower Faucet
I installed new moen shower valve i tested it before i put the walls up 6 months later finaly got done with bath room no water comes out now
During construction did you perhaps close off a shut off valve within the water line and not reopen it? If not do you hear anything at all when you turn the shower faucet on? Let me know.
Jul 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I bought a Danco 3H-10H/C, Hot/Cold stem. The problem is, it seems to be setup for hot (clockwise closes the valve, counter clockwise closes it). Is it reversable? Or is it not really a hot/cold...
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Jul 18, 2010 | Danco Faucet Stem
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When I turn the faucet to hot ,water comes out of the shower without pulling the shower pullup
either to much water pressure to unit or pull up is clogging /damaged if u have separate valves on water supply start at half way and work ur way open or close till water doesnt come out of shower head
Feb 15, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I have a single handle Moen faucet in my shower. It has not been used for a while , now that my kids are home and try to take a shower there is little hot water coming from the shower. The cold water...
probable that there is mineral deposit's,scale buildup,inside. pull cartridge and look in valve body,turn water on to it and flush valve body real good.possible model #1222-if it's posi temp ,#1225 for reg faucet
Jan 01, 2010 | Moen & One Handle Tub & Shower Faucet
Installed a new oak brook collection tub and shower faucet and no water comes out.
You may have to disassymble the faucet to see if there is something that is stuck in there or that the assymbly internally is stuck in the closed position.
Mar 19, 2009 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Shower/spout
The valve is installed upside down and needs to be reversed. There is a diverter in the valve that gives the spout priority. When the valve is upside down it gives the shower head priority. Thats why it runs without the diverter being activated. You will need to get in the wall from one side or the other. Cut the valve out and either flip the faucet Or change the direction of the diverter depending on the style of valve.
Good Luck, Phil
Dec 10, 2008 | Price Pfister 01-111 Shower Head, Tub...
Plumbing Logo
Top B&K Plumbing Experts
Dennis Mulford
Dennis Mulford
Tom Chichester
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
