Question about Ativa LD600 6-Sheet Cross-Cut Shredder
My ativa ld600 is about 4 months old and it stop working. I turn it on and it don't work, no light, nothing that shows it's plug in the outlet. I check the outlet and I got current in it. So, what is
My shredder is 5 months old or so. Last time I use it as soon as I plug it in the green light turn on but then when I was going to use the light hasn't come on. I checked the outlet for current and it was working. I tried several outlets and it don't turn on. Is there a fuse somewhere that I have to check? Last time I use it, it was working okay. Tell me what to do.
My polaroid lcd tv, wont turn on, its 16 months old, any ideas?
Try plugging it into another outlet - one which you are certain is working. If that doesn't work, you might have a bad fuse inside your TV. If that isn't it, the power supply board may have failed.
May 25, 2014 | Polaroid Televison & Video
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Stopped working
do you use windows os ? if true, try to open disk management from control panel. if your drive is detect there, try to re-partition it first, then format it.
Nov 05, 2013 | Buffalo Technology MiniStation Computers &...
Installed 8 low voltage lights with a malibu digital 120w timer 2 months ago. The timer does not always work. I'll unplug then power up the system and then the lights turn on. Never had this problem...
Timer is not identified:
Open following link to see low-voltage digital timers and then add a comment if needed:
Page also has links to warranty information, and list of advisories so power pack lasts longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#digital
There are 2 likely suspects: Bad timer, or electrical problem.
There is no repair for bad timer, but timer has warranty through the manufacturer/ Malibu.
Electrical: Since power pack worked correctly before, then outlet probably has correct polarity, but I always suggest checking outlet with circuit analyzer.
Also plug lamp into same outlet and see if there is flickering that would indicate loose wire. Wiggle circuit breaker and see if lamp flickers. Move the outlet and see if lamp flickers.
Outdoor outlets get loose wires because of exposure to temperature and dust and moisture. Replace outlet and don't use the quick connects, instead use screw terminals.
If possible, move timer to different outlet on different breaker and see if problem persists.
Oct 05, 2011 | Hardware & Accessories
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
Two months old dead no power
Check the Power cable of your PC for any damaged or burn/cut. Firmly check the connection on the slot of the CPU Power Supply,
Check the Electrical outlet , or better plug the cord on a different electrical outlet.
If all of this has nothing to do and the problem was still there, possible problem on the powersupply are, it is advisable that you have to replace this part, a possible burnt or a short circuit has happen inside, due to some electrical malfunction on your area.
HOpe this helps.
Let me know for any clarification
Oct 08, 2009 | ASUS Computers & Internet
Range master 50000 exhaust fan stopped working
Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
Jan 07, 2009 | Rangemaster Kitchen Hood
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Shredder won't turn on
ok " if the ready light did not come on it's telling you that there is no power sound like the plug in transformer is no good .
you can check that transformer , with a multimeter, see if you have the right voltage.
Jan 27, 2008 | Office Depot Ativa DQ60M Shredder
Ativa LD600 6-Sheet Cross-Cut Shredder Logo
78 people viewed this question
Top Ativa Office Equipment & Supplies Experts
k24674
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
