Question about Xerox Corporation Phaser 6600DN Laser Printer - Color - 1200 x 1200 dpi Print - Plain Paper Print - Desktop 36 ppm Mono / 36 ppm Color Print - 700 sheets Input - Automatic Duplex Print - Gigabit Ethernet - USB
Xerox 6600dn can it scan slides
Can i scan slides on the 6600dn
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Xerox Corpor... Expert
  • 142 Answers
If you mean can the printer print onto film slide to display on an overhead projector then I'm almost sure it can, however ensure the slides are of reputable quality i.e. Xerox slide material because the material will fuse and stick inside the fuser causing an expensive mess to rectify.
Good Luck.
Posted on Jun 02, 2015
My xerox 6600 keeps saying "invalid black" when replacing cartridge
The CHIP on the NON OEM cartridge is NOT current with correct firmware and as a result the cartridge(s) will NOT reset that a new cartridge has been installed.
Future hint...do NOT update as working printer drivers "ever"...as this is one way that the OEM's thwart the aftermarket TONER usage.
Good luck
Mar 13, 2016 | Xerox Phaser 6600DN
Why does it keep saying tray 1 is empty when its not?
Check the tray gears behind the try in question. With the tray removed from the printer and loaded with paper. Try to turn the rear lift drive gear. Does it lift the tray of paper?
if not check the gears closely. I suspect there broken, also look for fragments of plastic gear in the body of the printer.
if you have broken gears you might like to try shopping on the net for replacements.
Cheers,
Dave.
Feb 24, 2015 | Xerox Phaser 6600dn Color Laser Printer
How to reset waste toner
Open the compartiment on the right side of the Xerox 6600 or Xerox 6605. Rotate the orange lock and carefully take out the waste box. Now empty the excess toner in a bag by shaking the unit with the "holes" down. Do this for 10 minutes till all toner is out of the box. Do this outside, it will be messy.
Blow off any residue tonerdust and take a little screwdriver to remove the plastic seethrough cover. Remove the toner behind this cover and clean it with a cloth. Glue the cover back in place and re-insert the wastebox.
You will save you some money, but it is an unavoidable messy solution.
Aug 11, 2014 | Xerox Phaser 6600dn Color Laser Printer
My scanner is asking me to unlock the hardware, but the switch is already unlocked what do i do???
Some scanner models have a physical lock mechanism under them for use during transport that stops the scan head from sliding around. Check under your scanner if it has one and slide it along to the open/unlock position if it does.
Mar 07, 2010 | Xerox One Touch 2400 Flatbed Scanner
Xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
I wasn't sure of the model when I asked the question on the Xerox WorkCentre M20 where the scanner bar does not move or the lamp does not move but a few inches and goes back and stops!!! The model is a...
No, That would be different. I would UNPLUG the machine and remove the glass. Then slide the lamp carriage back and forth to see what it is binding on. Could just be a cover or hitting a sensor in the scan path. On that machine there is a home position sensor that the lamp will often catch on. You would feel it hit the bracket when you slide the lamp back to the start position. It would hit about an inch or 2 before it locates all the way back to the left. If thats it, you have to carefully bend either the sensor bracket or the metal flag onthe lamp carriage itself to hit the sensor centered.
Jun 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox 4150 not scanning to network
I need more information, like is it scanning using the SMB protocol or FTP. Are you using active directory, etc. Usually, when they just quit, it is due to a Microsoft security patch, or a software firewall having been enabled. If you're sure that it is neither of the above, try browsing to the Xerox via the IP address, go to the properties tab, services, network scanning, file repository set-up, and see if the login name used for network scanning is qualified: (i.e. - domain\username) Often, in a business environment, that will help.
Mar 20, 2009 | Xerox WorkCentre 4150 Black and White...
Describe your Xerox WorkCentre Pro 412... Problem:Scanner
Turn off the copier first.
Look under the copier, there by where the copies come out, look just above that portion of the machine. There will be a green sliding latch; one side has a picture of a pad lock for lock, the other side has a un-lock position, slide the latch to the unlock position.
Turn on the copier, and the machine should work.
That latch is for transporting the copier when being moved. It will hold the scanner in place so it does not move around.
Apr 23, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox Corporation Phaser 6600DN Laser Printer - Color - 1200 x 1200 dpi Print - Plain Paper Print - Desktop 36 ppm Mono / 36 ppm Color Print - 700 sheets Input - Automatic Duplex Print - Gigabit Ethernet - USB Logo
Top Xerox Corporation Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Xerox Corporation Office Equipment and Supply Expert? Answer questions, earn points and help others
