Question about 2wire (2701HG-B) Wireless Router
Power is not on
When I plug the adapter the power is not on
My screen does not turn on
  • Remove all power (adapter power Cord and Battery (for laptops))
  • Hold down the ON button for 30secs (dispersing internal voltage)
  • Plug the power cord in only (ie leave battery out, for the moment)
  • Turn on
Check your power adapter. Plug it in to a known good power receptacle. See if the power adapter has any lights that light up to make sure it is getting power.
Take the battery out of the laptop and just only plug in the power adapter.
Do any lights on the laptop light up when you power it on? Does it beep?Does it make a sound? Is where you plug your power adapter to your laptop loose or broken?
if no sound or light the its either power adapter , dc jack or cable, or system board .
Please note, it is also a good measure to re seat the memory.
You may need to locate your disassembly guide
Aug 14, 2014 | Compaq Presario R3000 Notebook
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
Hello. Today in the morning my laptop (Asus A8Jseries) was working alright. Then after 6 hours when i tried to turn it on, it didn't. I mean, it starts to work and Asus symbol comes alone, but then it just...
If it happens only when you move the adapter plug inside the power jack, it's likely that you have a problem with the power jack inside the laptop. The power jack has to be resoldered or replaced.
If it happens even without touching the adapter plug, the problem could be related to the faulty power adapter.
You can test the power adapter with a voltmeter and find out if the ouputed voltage is correct. If the voltage is not correct, replace the adapter.
http://www.chargerbuy.com/replacement-asus-a8-ac-adapter-19v-3-42a.html
But don't trust that even if the output votage matches specifications. It's possible that the power adapter doesnt' work correctly under load. Test your laptop with another known good adapter. If the laptop works fine with another adapter, your power adapter is defective and has to be replaced.
Mar 13, 2011 | ASUS A8J Laptop AC Power Adapter (4.3A...
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Hi there, When plugged in nothing happens. What could it be?
Only a few things come to mind:
1. The plug on the MB is defective
Solution: Have the plug on the motherboard replaced
2. The universal power adapter is defective
Solution: Buy an ASUS power adapter and test it out. If it doesn't work, return it. If it does, then get rid of the universal adapter.
Good luck
-Carlos:
Jan 07, 2010 | ASUS AC Adapter- Universal Notebook AC...
After a few minutes plugged in the power/battery lights flash
I would check the power adapter.
Test the power plug on the adapter with a multi-meter, the voltage should be slightly higher that the voltage that is printed on the label on the bottom of the power adapter.
If the voltage is zero or very low the the adapter is faulty and needs to be replaced.
If the power adapter is OK then the fault could be a faulty power socket on the laptop's motherboard. Plug the adapter's power plug into the laptop's power socket and wriggle the power plug, if the power/charge LED flashes then the socket may have a dry solder joint or the socket maybe faulty and needs to be replaced.
This is a common problem with laptops and to fix and/or replace the socket requires the laptop to be completely dismantled. Get a quote from a repair as it is not cheap.
Jan 22, 2009 | Toshiba Computers & Internet
2wire (2701HG-B) Wireless Router Logo
18 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
