Question about Do All Traps Do-All Backyard 3/4-Cock Single Trap
How do disarm a do-all trap thrower mfg#BY56
The trap thrower is always armed. how do you disarm
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
White wing thrower, will not stop throwing clays as soon as you turn it on.
[PDF]TROUBLESHOOTING AUTO TRAPS - kivelaoutdoor.com
www.kivelaoutdoor.com/.../TROUBLE%20SHOOTING%20AUTO%20T...
Is the throwing arm stalled while motor/gears are turning? ... "The Trap worked well at first but after a box of targets it started breaking a lot of .... Throwing Arm when to stopin the cocked position by killing the power to the motor when ... Arm doesn't move to the Disarm position when the unit is switch to Disarm, it could be that.
Sep 14, 2015 | Mtm EZ Throw II
How do I arm and disarm the alarm on my 94 gs 300
when you lock the doors it automatically arms itself. you can disarm by inserting the key in the driver's side door and unlock the door lock, it should disarm if the alarm goes off.
Mar 19, 2015 | 1994 Lexus GS 300
Hi, I bought a car a year ago with remote start installed & working, but I've forgotten how to "arm" it, or whatever you call it when it's ready to go. My vehicle is a Rav4 w manual transmission. The # on...
Easyest way is to find where is the car alarm box located on yiur car. And find out who made it and get a serial nr . Then go to manufacture web page and download a users manual. Remote starts are not all the same as you can get a cheep ine from china but the quality ones normaly are the tricky ones to play with
Dec 03, 2014 | Cars & Trucks
The arm on my clayhawk full **** clay target thrower won't throw!
Anything with this much force in it is dangerous to work on unless you are totally knowledgeable. Seek help from a shop/dealer.
Dec 14, 2013 | Do All Traps Clayhawk Full Cock Clay...
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Jul 16, 2009 | Vehicle Parts & Accessories
Replaced the alternator, now anti theft won't disable
The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
  • The antenna for the keyless entry remote transmitter.
  • 26 circuit connector (C256).
  • 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
  • The ignition is OFF.
  • The PANIC alarm is OFF.
  • All doors are closed.
There are two ways to prearm the system:
  • Press the LOCK button on the transmitter.
  • Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
  1. Pressing the UNLOCK button on the transmitter.
  1. Placing a key in the door and turning to UNLOCK.
  1. Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
  • The ignition cylinder is damaged with or without the RAP being armed.
  • A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
  1. Pressing the UNLOCK or PANIC button on the transmitter.
  1. Putting a key in the door and unlocking the door.
  1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
Apr 10, 2009 | 1997 Ford F150 Regular Cab
Do All Traps Do-All Backyard 3/4-Cock Single Trap Logo
496 people viewed this question
Top Do All Traps Sport & Outdoor - Others Experts
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
