Question about Maytag Dryers
I have a maytag ensignia gas dryer with a pull start/ timer-cycle selection. When the knob is set at the proper cycle or time, sometimes the pull/start mechanism does not work. We have to move the knob and re-pull the start several times to get the dryer to start. Which mechanism should we look at to repair?
SOURCE: Removing Timer Knob on Maytag MDE7400AYW dryer
I was having the same problem until I figured out that you can remove the front part of the knob by gently prying the silver/gray cover away from the rubber ring part of the knob. Once you remove the front part the rest of the knob can be removed.
Posted on Jun 03, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Posted on Mar 20, 2009
  • 16 Answers
SOURCE: Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Posted on Apr 11, 2009
Healeyman
  • 1198 Answers
SOURCE: sqeaking dryer
Find a heat resistant grease. It must say heat resistant. Then you will need snap ring pliers. The rollers are behind the drum, the whole machine must be taken apart, no fun. While apart, vacuum everything. Note how the belt goes before you take it off. A few extra screws while you're in there will expose the fan area. You will be suprised what you can find there.
Posted on Apr 22, 2009
erpaalai
  • 999 Answers
SOURCE: Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Posted on Sep 18, 2009
Aytag ensignia dryer model # is MDE7657BYW
Go for item 5 on this diagram. You can buy it off appliancepartspros.com
Parts for Maytag MDE7657BYW Control Panel Parts
Aug 24, 2014 | Maytag Dryers
I have a Maytag Ensignia washer that will fill with water and start working but will not advance to the next cycle without manually advancing the dial. once helped into the next cycle the washer works...
First you need to list the model number in order for me to figure out what type of washer it is then i can help you. The reason I ask is some Maytag Ensignia's come with electronic timers and some models have old style timers...
Mar 10, 2013 | Washing Machines
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
May 27, 2009 | Whirlpool LGR8648 Gas Dryer
The dryer has power but the start cycle knob only buzzes
IF THIS MODEL USES THE TIMER TO START THE MACHINE BY PULLING OUT ON THE KNOB, I HAVE HAD TO REPLACE QUITE A FEW TIMERS FOR THIS PROBLEM. SOMETIMES BY MOVING THE KNOB UP AND DOWN AND SIDE TO SIDE WHILE PULLING WILL START THE MACHINE. IF SO, REPLACE TIMER.
Nov 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Hard to start dryer, control know loose/misaligned
your saying that pulling the timer knob out, which normally starts dryer, does nothing. however if you pull out and apply pressure upwards on knob and touch nothing else, the dryer will start??? if the thats the case sounds like a short in the timer mechanism , youll need to replace the timer assy
Mar 18, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Wash cycle does not start!
if only rinse cycle work. it mean the cycle timer in no good. you need to replace it. i will tell you the cost of it later.
Feb 05, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
83 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
