Question about Sharp MX-2700N Color Copier
Black image streaks on sharp 2700n
Black only printing shows smeared areas on prints. Starts out fine, then problem builds.
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Posted on Mar 21, 2014
  • 67 Answers
SOURCE: Sharp AR BC320 not printing correct colors
First of all, this copier doen't have print heads that spray ink like an inkjet. Its print heads (4, one for each color) are LED arrays, all they do is emit light. They can get dirty, but not clogged with ink.
Suggestion: Make a color copy at the copier, then print a color picture from a workstation. If the copied page looks good and the printed one doesn't, the copier is probably OK. Reinstall the print driver. I suggest you download the latest driver just for effect.
This worked for me at a customers site just today.
Posted on Feb 28, 2008
mickspaceNET
  • 115 Answers
SOURCE: copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Posted on Oct 23, 2008
kram26
  • 544 Answers
SOURCE: Black lines running down the prints
it seems that your print head is the problem you can try to clean it first..
but if you already try to do this no other choice is to have a service center o change it for you.
thanks,
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
Posted on May 11, 2009
  • 1294 Answers
SOURCE: What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
Why are there lines in my photos
The manual says:
This phenomenon is called smearing. This is not a malfunction. Smearing is not recorded on still images, but is recorded as streaks or uneven colors on Sweep Panorama images or movies. ("Bright areas" refers to the sun or electric lights which are much brighter than surroundings.) It does not say a thing about lines in the prints. Are you sure the pictures do have lines too? Can you describe this more accurate?
Description online of Sony DSC-H200
Nov 25, 2013 | Sony Cyber-shot DSC-H200 20.1MP Black...
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Can print A4 but not photo paper
It looks like you have a problem with the pick up roller....try removing the roller and washing it with water dry properly and insert it back to place ..this is temporary fix.....and mite not work 2..u need to replace this roller....if it continues to trouble you
Oct 31, 2008 | HP PSC 1410 All-In-One InkJet Printer
Streaked & smeared printing on envelopes
Check area where the envelope is pulled into the unit. There may be some debris causing the ink to smear.
Sep 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Print Quality problem Xerox 7400DN
Opening a cover during printing will cause a paper jam. If you do this several times and carefully clear th paper you may be able to isolate the origen of the smudging.
Jul 17, 2008 | Xerox Phaser 7400DN Laser Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
Sharp MX-2700N Color Copier Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
