Question about Ovens
VISCOUNT EZ60GWF GAS COOKER MANUAL
INSTALLATION MANUAL
Zanussi installation manual
Please note this product should be installed by a qualified engineer, such as one of our Knowhow experts. My Currys Comparison
Aug 14, 2014 | Ovens
Manual for viscount oven
Got an viscount PC60 double oven
hubby broke the nob, but we don't know how to reach the inside to repair it
any idea ?
thank you
Nov 06, 2011 | Ovens
I have Terim Duel Fuel range cooker which at the moment can only be used by bottle gas/calor gas and not mains gas. Is there anyway it can be adapted to be used for mains gas?
you have to change the jets to the "mains" gas, usually these are found inside the back cover of the oven, sometimes it is only a wrench adjustment on the gas valves theselves.. look in your manual on how to do this, and if you don't have the manual, you will need to order it from the terim company
Mar 11, 2011 | Ovens
Installation instructions for Indesit 90cm upright cooker dual fuel model number KP59MS
You can get the manual on the link below.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Cooking/KP9508E(X)G_195046972-03.pdf
Good Luck please rate 4 thumbs up for the free answer and please leave a testimonial
Oct 06, 2010 | Ovens
I am looking to get an aga cooker instaled gas with my own corgi reg fitter and need assembly instructions
Installation really isn't something that can be done from a set of instructions - it's more complicated than that and needs an AGA trained engineer to do it. Suggest contacting AGA Service for advice, as a badly installed AGA may not function correctly.
Sep 18, 2010 | Ovens
I need a set of installation instructions for a Leisure 2100EL gas cooker
how do i uninstall a hotpoint doubl aven 27 inch wide 50 inches tall chris
Feb 03, 2010 | Ovens
Gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Jun 21, 2008 | Stoves Premier 720GRa Gas Double Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
