Question about Makita Tools & Hardware - Others
Makita 1834 battery
Battery wont charge
5 Suggested Answers
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
rowdy45176
  • 2176 Answers
SOURCE: dont know when battery is charging.
there are usually lights on the charger to indicate what mode it is in. Let me know if not and I will try and locate a manual for this. If you do need that I would need the exact model number for everything
Posted on Jul 02, 2009
  • 4 Answers
SOURCE: makita cordless driver drill model-6347d.
You say will not stay charged? Over what time period? Are you aware Nicad and NiMh rechargeables discharge naturally at 1% per day so where does that leave your power tool after 3 months? Furthermore they only have around 1000 charges in their useful life so you can immediately see how these tools are not for intermittent(ie handyman) use.
Posted on Jul 03, 2009
kjhbwergw90142
SOURCE: makita lithium ion 18 v battery wont charge
Do not keep her on cold place. sorry but you have to buy new one again :/ take a look on amazon or something:
Amazon com Makita 18 battery
Posted on Dec 05, 2014
Makita radio working via electric but not on battery. battery is charged
Check the battery it may have a high internal impedance.
Nov 27, 2014 | Makita BMR100 Radio
How can I reset chip on my Makita lithium ion 18v battery
Based on experience I can tell you that it is is generally the temperature/cutoff/individual cell monitoring sensor in charger that dont allow the batteries to take a charge. Once the same condition is detected 3 times by the same charger it considers the batteries to be bad and refuses to accept it. I have 2 batteries that wont charge on one charger but works perfectly fine when i charge it on my other Makita charger so basically there is no problem with my batteries.
I would suggest first you check the voltage of your drained battery by a test multimeter. For 18volt battery if it is close to 18volts 1-2 volts less is just fine! Then there is no issue with your battery. Makita chargers are very expensive hitech which is useless in my opinion the lipo chargers (used in rc hobby) example skyrc are better quality cheaper and does a better job and you can easily charge your makita battery with it as well but this is only recommended if you decide not to go with Makita charger any more. Some basic information about multi chargers for Li-ion battery to follow the safety is make sure you use the right connectors with correct polarity. For 18v volts max voltage should not exceed more than 20.50 and the allowable charge current is 2.7amps also ensuring that batteries dont heatup.
Oct 05, 2014 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita battery wont keep charge
Given the problems with Makita Li-ion batteries there are 2 likely reasons, you have a faulty charger or both batteries are faulty, the best option is to find another charger to try your batteries on and see if they charge, depending on the age of the drill you may be able to get the batteries or charger replaced by Makita, a lot of them have been replaced out of the warranty period because they are known to fail prematurely, take the faulty item back to the place of purchase with you invoice and put the pressure on for replacement
May 03, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Hi both red and green lights are flashing and it wont charge battery bl1830 lith ion
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Sep 13, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita lithium ion battery wont charge
does it have green blinking light when you plug it to mains w/o battery in it ?
Apr 06, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an...
tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
Dec 16, 2009 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
Makita cordless driver drill model-6347d. ni-mh rechargeable nickel metal hydride battery 1834 18v 2.6ah will not stay charged. battery charter dc 1804- works great.
Mar 03, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Tools & Hardware - Others Logo
15 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
