Question about Toyota Vehicle Parts & Accessories
Toyota yaris 05 highbeam stuck on
High beam stays on when switch is off and car not running
    Sergeant:
  • 462 Answers
Sounds like your hi lo switch is gone
Posted on Sep 07, 2014
2007 toyota yaris high beam light is lit dimly when high beams are not on
Water in connection. Unplug and use some electrobe lube or Vaseline on the connections.
Feb 18, 2016 | 2007 Toyota Yaris
2001 subau high beam lighton when lights on
If you believe it is the highbeam indicatore just try using the switch to change it to low beam and it may go off other wise it is probley just an indicator that your daytime running lights are on.
Apr 01, 2014 | 2001 Subaru Outback
High beam indicator stays on when turn on lights
Highbeam Symbol problem
The high beam and low beam works the opposite for my Mitsubshi Montero 1998, when in low beam the high beam SYMBOL comes on and when i flick to highbeam, the symbol comes off
Jun 01, 2011 | 2005 Ford Focus
07 yaris high beams work, but low beams doesn't. what do you think i need to do? change light bulb?
The problem is most likely the the low beam relay or the combination switch
Mar 09, 2011 | 2007 Toyota Yaris
1998 Windstar - the high beam lights won't shut off
CHECK THE DIMMER SWITCH. THE SWITCH MAY BE "STUCK IN HIGH BEAM POSITION. THE STEERING WHEEL WILL HAVE TO BE REMOVED. ANOTHER THING TO CHECK FIRST IS THE HIGH BEAM RELAY. THIS MAY BE UNDER THE HOOD IN A FUSE PANEL OR UNDER THE DASH. HOPE THIS SHEDS SOME "LIGHT" ON THE SUBJECT..lol
Mar 15, 2010 | 1998 Ford Windstar
My 1991 Caravan headlights won't turn off and the highbeam indicator light stays on. I've been told that the problem is likely the daytime running lights module. Where is this module located in the vehicle...
Sounds more like a stuck high beam relay. Daytime running lights module appeared sometime after '99 year. The relay should be in the fuse compartment. Pull it out to check that it is only the high beam that is on. Pull the low beam relay and place in the high beam location. If it turns on the high beams again, then try the dimmer switch to see if they go out. If that has no effect, then there is a sneak path somewhere that is turning the relay on.
Sep 06, 2009 | 1991 Dodge Caravan
Highbeams
Are you sure it's your high beam and not your DRL. Your DRL light will always be on through the day when you do not have your lights on. Indicating that your drl's are on. DRL (Daytime Running Lights) are your high beam headlights at a low wattage. The only other sympton could be that you have a burnt out headlight and this is telling you so, by having the H.B. light on. on your dash.
Dec 18, 2008 | 2005 Chevrolet Cavalier
Only high beamheadlampswork.fusesok
I would look at the relay contact and connector for signs of corrosion or poor conduction. The relay may be okay but the terminals often get enough corrosion to interfere with electrical conduction.
Oct 05, 2008 | 2005 Suzuki Forenza
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
fordexpert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
