CANNOT FIGURE OUT HOW TO CHANGE RADIO STATIONS
SOURCE: How can I reset radio stations?
please try timex; Timex Corporation 555 Christian Rd. Middlebury, CT 06762 CT Tel. 203-346-5000 Fax 203-346-5139 i have been unable to find one online - best thing to try is see if you can find a dealer who is selling it and ask if you can copy a manual - they may oblige. Hope this helps a bit :)
SOURCE: Programming the radio stations
Go to the station you desite press and hold the number until you hear a beep, about 5seconds
SOURCE: cannot figure out how to set favourite radio stations on my Clok
I just spoke to tech support. They said not being able to set the radio station to 96.1 is a PCA hardware problem. They asked me to get the product exchanged.
SOURCE: 3"X2" HD) radio by Insignia Radio
I'm assuming that you have tried to reset the radio with the button on its side and it didn't work. In that case this isn't a software - or commands - problem that can be fixed with owner commands, it's hardware: the processor of the radio got stuck because its firmware got corrupted.
All you can do is to force a complete reboot: with the radio working disconnect the battery; join the battery pin connectors for an hour to discharge all residual electricity from it (use a small piece of tin foil); plug it back - if the processor is still operational and the firmware chip intact the full reboot will take place and the radio should start functioning correctly. If this doesn't happen then the radio has failed - not worth repairing, just get a new one.
