Question about Do All Traps 3/4 Cock Trap -
How do youuncock a do-all 3/4 **** trap thrower
Trap thrower is always 3/4 cocked. how do you uncock it
White wing thrower, will not stop throwing clays as soon as you turn it on.
[PDF]TROUBLESHOOTING AUTO TRAPS - kivelaoutdoor.com
www.kivelaoutdoor.com/.../TROUBLE%20SHOOTING%20AUTO%20T...
Is the throwing arm stalled while motor/gears are turning? ... "The Trap worked well at first but after a box of targets it started breaking a lot of .... Throwing Arm when to stopin the cocked position by killing the power to the motor when ... Arm doesn't move to the Disarm position when the unit is switch to Disarm, it could be that.
Sep 14, 2015 | Mtm EZ Throw II
The arm on my clayhawk full **** clay target thrower won't throw!
Anything with this much force in it is dangerous to work on unless you are totally knowledgeable. Seek help from a shop/dealer.
Dec 14, 2013 | Do All Traps Clayhawk Full Cock Clay...
The machine at times just keeps on shooting out the clays when not even pressing the remote peddle. It does it even without the remote plugged in.
For something like this, I think your best bet is to contact the company:
Do-All Outdoors, LLC.
1207 16th Avenue, South
Nashville, TN 37212
Customer Service:1-866-SHOT-DOC(1-866-746-8362)Email:customerservice@doalloutdoors.com
General Numbers:
phone:800.252.9247
615.269.4889fax:800.633.3172
615.269.4434
Oct 07, 2013 | Do All Traps Do-All Outdoors White...
I cocked 2.2 bsa airiffe and it,s not fireing why not
Without more info I can only guess. I assume the safety is off and the pellet in chambered. That being said there is a possibility that the seals are gone and leaking air so no matter how much you pump it if ti can't hold air pressure then it won't shoot.
Aug 03, 2013 | Hunting
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
Aug 05, 2011 | Garden
Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
assistance
i hope this helps you
bob
Jun 07, 2011 | Craftsman Garden
Doing a brake job on 2007 Uplander LT and cannot get the piston back in with C Clamp, help?
u need a special piston rest tool that turns the piston clockwise into the capiler .. to reset it.. most parts stores carry them,,,
Aug 17, 2009 | 2006 Chevrolet Uplander
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Do All Traps 3/4 Cock Trap - Logo
355 people viewed this question
Top Do All Traps Sport & Outdoor - Others Experts
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
