Question about Sanyo DP50749 50 in. Plasma TV
Sanyo DP50749 3 vertical lines
3 vertical lines
Horizontal lines on a sanyo 46848
The Vertical output Stage of the TV is Faulty. Can be drysoldering joint in the leg of vertical output IC Or the vertical output ic is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 25, 2016 | Sanyo Televison & Video
Why does my sanyo flat screen TV have vertical coloced lines on screen with no picture?
Check the ribbons going in between the boards and "work" them to clean up all connections. And on the main board look for possible bad caps.
Your t con board is responsible for all picture distortions but not the vertical lines you described.
Feb 25, 2016 | Sanyo Televison & Video
My Sanyo 50 inch tv has black line going vertically down , what can I do too fix this problem ?
Hello. I'm sorry, but lines in the screen, either vertical or horizontal, in 99% of the cases is not repairable without changing the panel. Some of the older TVs you could change a buffer or drive board, but those days are pretty much gone.
May 30, 2015 | Sanyo Televison & Video
Sanyo video vertical lines
There are two possibilities.
1. Deflection yoke mismatch.
2. Shorted component/s at its horizontal oscillator section circuit or at its main power supply regulator [SMPS].
Contact any service technician
Feb 14, 2015 | Sanyo Televison & Video
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Manual
did you try their web site
sanyo.com
Feb 03, 2009 | Sanyo DS31590 31" TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Vertical
what have you picked. to the tv
Jul 12, 2008 | Sanyo DP32746 32 in. LCD Television
Vertical line
Hi there!
This is called a frame collapse. The Amp that drives the vertical sync has failed. This could be from excesive voltage on the mains, Lightning in the area, if you had or simply general failure. May also be dry joints( or loose connections) in the vertical amp or scancoil terminals. Good Luck,JUS004
Mar 05, 2008 | Sanyo DS35510 35" TV
Sanyo DP50749 50 in. Plasma TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
