Question about Mamoru Tokashiki Voice Recorder
Voice recorder black screen
Can't open, only black screen
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
HOW DO I SET UP VOICE MAIL ON MY GOOGLE VOICE NUMBER
You need to log into the web page and use a registered phone to record messages.
https://www.google.com/voice/
Go to the GEAR drop down on far right side of screen. Then select SETTINGS. A new page opens, then select VOICEMAIL & TEXT tab
The record option is right there. If you have not linked the Google Voice number to a real phone yet, you do that on the PHONES tab.
Jun 03, 2014 | iPhone Apps
Create ringtone from voice recording
Download an app for ringtones, after that record something you want to use with your voice recorder, name it anything you want so you can recognize it. Then open the app ringtone open your file edit your file the length you want and save it. Then use it on people you want or use it as default. Good luck.
Nov 08, 2013 | Boost Mobile Lg Venice No-contract Mobile...
I have a JNC digital concept power voice II
The part which shows the files to be downloaded from the JVC recorder does not open when the software starts up. It only opens when the recorder is detected attached to the USB port. I suggest 1. Start the software. 2. connect the JVC recorder to the PC with the USB cable. 3. Turn the JVC recoder ON. The recoder display says "PC link" and the files to download show up in Power Voice II on the PC. Michael C
Sep 30, 2009 | Audio Players & Recorders
My Digital voice recorders screen wont display...
Pull the battery out and let it sit for 2 minutes,reinstall the battery,if that doesnt work save your recordings,and then format the recorder.If still no success,send it in to olympus for service
Feb 07, 2009 | Olympus WS-311M Digital Voice Recorder
Record to PC window won't open
go through device manager and update driver for the device
Jun 26, 2008 | Olympus VN-2100PC Digital Voice Recorder
Problem finding saved sound
Symbian OS/S60 phone: With the Voice Recorder on the screen, open Options. Select Go To Gallery. All the recordings you have saved can be accessed from the Gallery. You should see a list of recorded tunes. Highlight a recording, open Options and choose "Set as ringing tone." Windows Mobile phone: When you are still in the Voice Recorder, highlight a recording in the list and open the Menu. Select Set As Ringtone.
If your phone menu doesn't show the Set As Ringtone choice at all, you have to set it manually. Go to the Home screen, push Start, and open File Manager. You have to move the recording from the folder /Storage/My Documents/Notes to the folder /Storage/Application Data/Sounds. Then, go to the Start menu and launch Settings. Select Sounds, open Ring Tone, and pick up the recorded ring tone.
Jun 02, 2008 | Samsung SCH-u340 Cellular Phone
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that moz-screenshot.jpgmoz-screenshot-1.jpgto record your voice let go when finished
Feb 21, 2008 | Motorola Mobility RAZR V3
Voice record!!!!!!!
Press the big side button on the right. Hold it down while the phone is flipped open. Then it should work, hope this works.
Jun 13, 2007 | Motorola Mobility RAZR V3
Problem with voice recording and notes
Remember that Pocket PC does not actually close programs. If you have opened many programs, then they are still resident in memory, and the system may slow down. You may wish to use the Switcher Bar. You will find it under Settings. The Switcher Bar allows you to switch between open programs. It also allows you to Exit all programs, which will free up RAM.
Sep 14, 2005 | Dell Axim X3 Pocket PC
Mamoru Tokashiki Voice Recorder Logo
69 people viewed this question
Top Mamoru Tokashiki Apps Experts
Brett Duxbury
Brett Duxbury
Are you a Mamoru Tokashiki App Expert? Answer questions, earn points and help others
