Question about HP LaserJet 2840 Printer
The printer may be out of toner.
Printer won't print
Kyocera EP470DN - Has Toner - Won't Print
MHHH, it seems as if its empty but it might be that it has humidified. Take out the toner and shake it side ways without compassion, then you slow down and shake it gently a couple of times then install it at the drum. You can also verify if this is true if you take out the toner and watch the roller and see if its loaded with toner. If it looks shinny with almost no toner it what I just exposed. Luck
May 10, 2013 | Kyocera Mita EP-470DN Toner Black EPT-470
Won't print text
It is difficult for me to say with certainty without seeing an example of the prints, but it sounds as if the black toner powder is not being printed. I say this as your printer should not be able to differentiate between text and graphics.
It is hard to say whether the toner cartridge or drum unit is the likely culprit, but you can probably get a good idea based upon what consumables have been changed recently.
The only other potential cause that springs to mind is that something in the configuration of whatever software you are printing from is set to only print images.
Nov 29, 2012 | OKI C5150n Led Printer
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
HP LaserJet 2840 Printer Logo
Seeker5211
Seeker5211
