Question about Apricorn 120GB Aegis Vault 2.5-inch 128-bit AES Hardware encrypted hard drive 120 GB
Aegis Vault A25-VLT-***. What screw driver do I need to open this. I need to change the lead.
USB lead cuts out
How do I change the temperature on the Aegis Scientific 3-CR-12? There is a blue digital box on the top of the unit.
We are having the same problem and my understanding is, we can not adjust it. It needs to be set before it is delivered and once delivered can not be reset unless it is sent back. We have had a repairman come out to fix a loose wire on our new fridge and he tried to contact aegis customer support but was unable to reach a live person in that department. Still waiting ....
Jan 19, 2015 | Aegis Scientific 3-CR-12 12 cf Laboratory...
Aegis padlock 3.0 blinking light from password wrong
This is why I never recommend using password protected file systems...if you forget the password you are screwed and almost no one can retrieve the password from you because even it's storage is encrypted. Sadly, I therefore must suggest that you just kiss the data on the drive "good-bye!"
Jul 09, 2014 | Apricorn Aegis Padlock DT USB 3.0 2 TB...
Free agent drive displays only$AVG8.VAULT$
open AVG select the history tab
then select vault you will see all items/files in the vault select the ones you want restored
being in the vault they are not active by restoring them they will become acive again
Nov 21, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Sony Micro Drive USD5G not recognized. I plug it in and computer does not see it. Same effect on all computers tried on. Any suggestions?
You should connect the sony micro device to your computer once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually it might be listed as a mass storage device click start right click on my computer you should see your mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll through all of the devices if you see a yellow question or exclamation mark or a red x you will need to update the driver right click on the device to update driver
if your computer came with a motherboard disc the drivers could be on it
if you can see your usb but its not working
ports(com&lpt)right click update driver :hope this helps:
Jul 05, 2011 | Sony Micro Vault Pro USD-5G (USD5G) 5 GB...
My usb can' formate and open
Try formatting it using windows explorer. if the drive where your flash drive is plugged is recognized by windows explorer and the drivers have been installed but if not perhaps your flash drive is defective and need to be replaced..
Jul 02, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Lost my sons combination to open mini vault bank
Turn right 39, then left to 6. I used a screw driver to open the case then reverse engineered the combo.
May 04, 2011 | Kikkerland Mini Vault Bank - Red
The green light won't go off on my sony 2gb micro vault thumb drive, and it won't show up on computers. I had been using it earlier today. I use it on macs.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Mar 02, 2011 | Sony Micro Vault Pro USD-2G (SONYUSD2G) 2...
Driver for Sony Micro Vault Midi 8GB USB 2.0
check this program is free www.radarsync.com
Dec 04, 2009 | Audio Players & Recorders
Is there a driver to allow sony micro vault 2.0gb on win 98?
Specs say it is compatible with Windows 98 SE. Also says no drivers are needed for it. Make sure your plug 'n play is enabled on your computer. Once it is enabled just plug the drive in & Win 98SE should install it. If it does not work then try a different usb port as maybe a port is bad. Hope this helps.
Jan 26, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Apricorn 120GB Aegis Vault 2.5-inch 128-bit AES Hardware encrypted hard drive 120 GB Logo
12 people viewed this question
Top Apricorn Computers & Internet Experts
Frank Zabroski
Frank Zabroski
ccsi99
dmhandyman
Are you an Apricorn Computer and Internet Expert? Answer questions, earn points and help others
