Question about Dell OptiPlex GX280 PC Desktop
Dell gx280 one beep then keyboard goes dead
On start up when it gets to the log on stage the windows logo comes up, the computer does one short beep and the num lock light will not turn off, the keyboard will not operate so I am unable to log in.
    Problem Solver:
  • 10 Answers
The only thing I can think of is that you might have some muck under the keyboard. See if you can get someone to clean out the inside of your keyboard. Hope this helps.
Posted on Mar 21, 2014
Kevin Amandy
  • 37 Answers
SOURCE: dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Posted on Dec 18, 2007
  • 18 Answers
SOURCE: trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Posted on Dec 06, 2008
  • 565 Answers
SOURCE: can't boot my Dell Optiplex GX280 from the
u need to use the sata drive floppyor windows xp corporate with sata drivers. can download from torrents.
If helped rate fixya
Posted on Mar 07, 2009
SOURCE: Dell Optiplex GX280 -ABC LIGHTS LIT UP IN BACK USB-HIGH FAN SPEED
system halted my pc help
Posted on Feb 25, 2010
  • 66 Answers
SOURCE: help i have a dell inspiron 530s and all of a
Try restoring your system bios to factory default and this may fix your problem. If not- post again with results and we'll go from there.
Entering System Setup
Turn on your computer.
When the blue DELL logo is displayed watch for the F2 prompt to appear (black screen / white text).
Once this F2 prompt appears, immdiately press F2 .
The F2 prompt indicates that the keyboard has initialized and is detected. This prompt can appear very quickly. Watch for it to display as the screen powers up, and then press F2. If you press F2 before you are prompted, this keystroke will be lost. There is a small window of time to do this before Windows starts.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then, shut down your computer and try again to enter setup. At setup check your bios version. It may need to be flashed (upgraded). Select load factory defaults to see if that will resolve your PCI issues.
Posted on Jan 16, 2011
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
Pressing the CAPS LOCK or NUM LOCK there is a beep.
launch the Toggle Keys dialog box by holding down the Num Lock button for five seconds, and clicking Yes. Thereafter, a loud beep will sound through your computer's speakers whenever Caps Lock is turned on or off. (To turn Toggle Keys off, once again hold down your Num Lock button for five seconds.)
Nov 11, 2013 | Toshiba Satellite Computers & Internet
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
What does it mean when the caps lock light and num lock light flash and the computer beeps?
If your cap lock light blinks on and off, and your machine is beeping at you, it means you are about to shut off for overheating. Clean out your vents, grease your fans, and see what happens. You may have intermittant fan failure, with a fan about to stop functioning, or maybe its not working at all.
May 03, 2012 | Sager Computers & Internet
Whenever I start my computer, it shows the Sony Vaio logo and right after that my computer starts beeping while staying at this logo. Sometimes it starts with windows restore and then it froze there and...
The beeps are a code to let you know what failed during the Power On Self Test (POST)
Count the beeps - and whether long or short. (Like 3 longs and 2 short, etc)
Go online to the Soony web site, or search for Sony POST codes. A list of codes will tell you what is failing - such as ram - or hard drive, etc. I suspect the latter.
Dec 06, 2010 | Sony VAIO VGN-FE770G Notebook
Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Jul 04, 2009 | E-Machines eMachines Desktop PC
I restarted my computer and keyboard not working
It sounds like you might have accidentally turned on the laptop number lock. I am assuming you are seeing that characters are being typed, but the password is not accepted. If this is the case, try turning off the num lock by pressing the FN key (usually found by on the lower left by the CTRL and/or ALT keys).
If this doesn't work, trying entering the BIOS when starting the computer (usually by pressing F2 repeatedly when you see the DELL logo). In the BIOS look for an option for the numlock and turn it off.
Last shot - I have seen a few times where num lock is remembered when an external keyboard is used and then stays enabled on the laptop after it is disconnected. If you used a plugged in keyboard and/or use a docking station, you may want to try plugging in the keyboard again, disable NumLock (above the number pad on the right) and then shut down. Remove the external keyboard and I suspect the laptop won't have this issue.
Hope this helps,
Chris
Mar 23, 2009 | Dell Inspiron 8600 Notebook
Dell OptiPlex GX280 PC Desktop Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
