Question about Vizio 60" E601I-A3 Full HD LED-LCD TV
I forgot parental code to factory reset mi visio tv
Part no. 10253010031 serial no. LFTRNWAP1605866 FCC ID:VQF-RT5390
Resetting parental controls
there seems that only 4 digits are the max but I could be mistaken, as far as reseting the password there is nothing listed on the Vizio website in the manuals ect for reseting the parental controls, probably due to security for the owner.
But there is a solution
if you call 877 MY V I Z I O
with you model number of your unit and make them aware of the parental lock issue there might be a way for them to explain the resting everything back to factory settings.
Aug 11, 2008 | Televison & Video
I have changed the security code and i forgot it
What is the specific model of your Nokia phone? If you have forgotten the security code, You can do a master reset to it. This would restore your phone to default factory settings. If your Nokia phone is one among the model of DCT 2/3/4 you can get the master reset code from www.unlocking4free.com/nokia-master-reset-tool for free.
Oct 08, 2012 | Nokia Cell Phones
Forgot the network security key (or my password) for D-Link WBR-1310,54Mbps,802.11g Wireless G Router,P/N:CWBR1310ANA..B1, S/N: F3RO183002877, MAC ID:001E58377258, FCC ID:KA2WBR1310B1, IC:4216A-WBR1310
reset the router to factory default. if you are confident. it is a small button at the back. press it coupel of sec then release. Then you can reset the password.
Jun 26, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Nokia E66 is no network, I cannot reset the factory settings because I forget the password FCC ID: PYARM 343 350906185988726 CODE 0518687 WLAN 00247C571701 IC 661V-RM343
Hi Mahesh , if you have forgot your password then simply go to mobile repairing shoppe and tel him they have mobile editing software through which they recover password and they will tell you your mobile password , they hardly take 50 Rs
Jun 06, 2011 | Nokia E66 Smartphone
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I NEED A UNLOCK CODE FOR MY SAMSUNG SCH-a870 SERIES SCH-a870 601-941-3981 MODE NO#SCH-A870 FCC NO#A3LSCHA870 NOTE: CAN'T GET IN MY PHONE
To unlock your Samsung SGH600 mobile here is a code *2767*3855# it will reset eprom.which removes SP lock.
For A series samsung the unlock code is
*2767*637#.this code reset your mobile.
Feb 21, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
How to disable parental lock
Go in and reset the code.
Jul 02, 2008 | Televison & Video
Open Questions:
See all Vizio 60" E601I-A3 Full HD LED-LCD TV Questions
Vizio 60" E601I-A3 Full HD LED-LCD TV Logo
24 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
