Question about Eiki LC-XL100 LCD Projector
Factory settings how to make facoty settings
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Mfc7340 where is factory reset
Restoring all settings to the factory settings, you can restore all the settings you have changed to the factory settings. These settings will stay until you change them again.1 Press Print Setting.2 Press a or b to display Factory Reset.3 Press Factory Reset. 4Press Yes to confirm.5 Press Stop/Exit.
Jun 10, 2014 | Office Equipment & Supplies
Factorial key
14! is an eleven-digit number. The only way your ten-digit calculator can display that number is to convert it to scientific notation. A twelve-digit calculator such as a TI-89 can display that number, but 23! is a 23-digit number and even a TI-89 cannot display that number.
Oct 25, 2013 | Texas Instruments BA-II Plus Pro...
Where is the fuse for cigarete lighter and what number fuse on 2002 vauxall astra club
Check you local EU internet for the facoty site to download the owners manual for this car, it is free I think.
Oct 14, 2012 | GMC Cars & Trucks
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
How do I reset my Panasonic DMC-FX35 to facoty
you'r menu should have a reset setting, there are 2 menu's 1 when you'r ready to take a picture & 1 when you'r viewing you taken pictures
Jan 14, 2010 | Panasonic Lumix DMC-FX35S Digital Camera
I forgot my personal security code for nokia 6263. Can you help ?
if you forgot your personal security code. so first you have to determine the security code is entered by you or factory setting . if facoty setting code is there 1234 of 12345678 and your personal code may be from 0000 to 9999 so its only possible through computer reset. so you have to go to nokia care and reset the phone.
Dec 28, 2009 | Nokia 6263 Cellular Phone
How to set the watch to its facoty setting
citizenwatch.com have manuals you can download.
Jul 10, 2009 | Watches
I have a vitodens 100-w combi boiler and tried to turn the heating on just to give it a working as was advised. However, I have no heat coming to my radiators. The boilers seems to be working as my hot...
Here's the deal: If your Vitodens 100 has outdoor temperature sensing capability, either built in or via external aftermarket control such as Tekmar or other, and the temperature outside is above warm weather shut down (WWSD), then the boiler will not operate for space heating, but will operate to make Domestic Hot Water (DHW) only. Generally speaking WWSD is facoty set at 20*C, since this is normal room temperature so the boiler will not need to operate at temperatures above this number as it is warm enough outdoors to heat the house to comfortable levels.
If your Vitodens 100 does not have outdoor temperature sensing capability then you should check to see if your room thermostats are operational and calling for heat since the boiler is only responding to this on-off control based on room temperature. (turn up your room thermostats)
In both cases you need to make sure that your heating system's distribution pump and zone valves are operating correctly.
In any case you should be calling a heating contractor if you suspect that there is a problem with your boiler and/or heating system.
Good luck.
Aug 07, 2008 | Heating & Cooling
Eiki LC-XL100 LCD Projector Logo
18 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
