Question about Dewalt DW087 Self-Leveling Split Beam Laser Line
Will not self level - Dewalt DW087 Self-Leveling Split Beam Laser Line
    Problem Solver:
  • 9 Answers
What is the exact problem?
Posted on Dec 17, 2014
My dashboard self levelling light turns on after a short distance like 8 miles ......do I need to top up hydralic oil
What is self leveling? Worked on many Fords, Haven't seen this one..Especially on Explorers.
May 02, 2016 | 1999 Ford Explorer
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
How do I fix the self leveling shocks in my olds bravada
it is a air shock ,and check and see the condition of the shocks. you may need to replace all 4 shocks
Jan 27, 2013 | 2003 Oldsmobile Bravada
The level line is not level. Is there a way to adjust it
find the adjuster on the bottom. if a self adjuster, return it where you got it.
Dec 24, 2009 | Cross Cst Stanley No.CL2 Fatmax Line Self...
Top loose, new dryer not level? rattle when start
No dryers are not self leveled. You may not have put the legs on ? they come in the box or if you have then you need to prop them up with a 1x4 or something.
Apr 19, 2009 | Kenmore 500 6952 Dryer
Nivomat self- leveling or not.
Automatic self-levelling is standard on the seven-seat models. What model do you have?
Oct 04, 2008 | 1990 Volvo 740
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Dewalt DW087 Self-Leveling Split Beam Laser Line Logo
201 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
Matthew McGuire
Level 1 Expert
Richard Warren
Richard Warren
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
