Spin is not working
It shows error code 12
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
Nov 17, 2016 | Washing Machines
What does code F-21 show
If it's a bosch machine F21 is motor control board error you would first test the motor to see if that was where your fault was coming from and if the motor tested positive you would then look at your control board.
You can reset the error code by the follow steps.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Apr 12, 2016 | Washing Machines
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
Apr 03, 2014 | Bosch Logixx WFT 2806 Front Load...
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hi, How Can I Reset error in my wash machine Bosch
Turn the knob to the off or reset position, 12 o'clock.
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
94/95 jeep 4 lt. Seem to have error code 12 followed by 55. Manual we have doesn't show 12 as an error code - any clues, please?
12 indicates that the battery has been disconnected recently. 55 shows the end of the code sequence.
Therefore, whatever problem you are having, it isn't generating a code.
Apr 21, 2011 | Jeep Cherokee Cars & Trucks
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
Maytag FAV6800AWW TL washer is throwing error code uC even when running empty cycle. It sounds like there may be a bearing going bad as it is more noisy than it should be when spinning. It stopped at 12...
Don,
I ask folks to give me some feedback when troubleshooting dC/uC errors with a feel for Wash Basket CCW/Spin direction drive system resistance.
It sounds like the Outer Tub Bearings are going which means you have a Tub Seal Leak that took them out. The Clutch One-Way Roller clutches are probably contaminated. I would bet a bit rusty and are sticking not locking up completely in Spin Cycle causing tumbler movement at the start of Spin Cycle. See my Clutch Fix post I go into a lot of detail for a fix and just what is causing the unbalance errors in Spin Cycle
You could drop the clutch out and see if you can clean up the bearings and relieve the dC/uC unbalance errors for a while longer.
Replacing the bearings is a bit more work see these post for what is involved. If your series is a 12 or above you may have to do as this forum member did.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
Series 10 & 11 from what I have learned use the upper One-Way Roller Clutch bearing ring and not the integrated Lower Outer Tub bearing as in I believe the Series 12 and above do.
Series 10 Outer Tub Bearing work I and another forum member are working on. The links will give you some direction if you DIY. http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
What are the first two digits of your Serial Number? Will be 10 through 17.
Post back if we can help I’m an owner like you not a repair person. I feel the cost to have the Outer Tub Bearing replaced will trigger you to make a replacement decision……Rich
Mar 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Mar 10, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
