Question about Mitsubishi Electric FR-A720-00610-NA Mitsubishi A700 Variable Frequency Drive, 20HP 240V
I M USING A700 VARIABLE FREQUENCY DRIVE WITH 130 TON INJECTION MOLDING MC,BUT WHEN MOTOR START DISPLAYING THE PROBLEM E.GF ,PLS TELL ME THE SOLUTION....
I M USING A700 VARIABLE FREQUENCY DRIVE WITH 130 TON INJECTION MOLDING MC,BUT WHEN MOTOR START DISPLAYING THE PROBLEM E.GF(EGF){OUTPUT EARTH PROBLEM} ,PLS TELL ME THE SOLUTION....
Bought a 702-33 taylor 3 phase ice cream machine. Is there a way to change it to us single phase?
Running a three phase motor on single phase power is simple. First you'll need to invest in a variable frequency drive. We recommend using the SMVector Series Variable Frequency Drive for multiple reasons. The SMV is simple to setup and easy to wire. It also comes standard with a NEMA 1 enclosure which gives basic dust and water drip protection. Most importantly, for the purposes of this post, the SMV comes with a number of different single phase input options up to 3 HP
Apr 26, 2017 | Taylor Ice Cream Makers
What is plastic injection mold mean?
Plastic injection mold is one of the most commonly used molds in manufacturing thermoplastic products. The processing equipment matching with plastic injection mold is plastic injection molding machine. Firstly, plastic is heated and melt in bed charge cartridge heater of injection molding machine. Then, the plastic enters into cavity of mold though nozzle of injection molding machine and gating system of mold, under the promotion of screw or plunger of injection molding machine. The plastic is cooled and hardened for molding, ejected for products. The structure generally consists of molding parts, gating system, guiding parts, ejecting mechanism, exhaust system and supporting parts. Making materials usually adopt plastic die steel, mainly including carbon structural steel, tool carbon steel, tool alloy steel and high-speed steel. Injection molding is only suitable for manufacturing thermoplastic products. Thermoplastic products made by injection molding are quite wide. Daily necessities, complicated machineries, parts on electric appliances and vehicles are molded by injection mold. It is the most widely used in manufacturing plastic products.
Dec 21, 2016 | Cars & Trucks
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
What type of oil doe it use
10W-30 Turf Gard
http://www.greenpartstore.com/John-Deere-GF-3-10W30-Turf-Gard-4-Cycle-Motor-Oil-Quart-TY22029.html
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Need instation dry machine220v60hz to22050hz at chile south america
You could replace the motor and the motor control board with ones rated for the lower frequency. Or you could use a Variable Frequency Drive (made by companies such as Allen-Bradley, ABB, etc) or simply try running the machine. The frequency determines how fast the motors will spin. At 50 Hz the motor will run approximately 17% slower, i.e., if the motor ran at 100 rpm it would now run at 83 rpm.
Apr 30, 2014 | Kenmore 7.3 cu. ft. Electric Dryer with...
Looking for W4180H frequency inverter/motor control
guarantee vacuum and sewing center or order directly off of the website
Mar 19, 2014 | Vacuums
What is the variable frequency drive?
VFD is a device used for speed control of 3ph induction motors & automation process control
Mar 18, 2013 | Hitachi Variable Frequency Drive Inverter
I am looking to buy a Delta Inverter VFD007M21A. Where can I get one and how much.
You can search it in Google or Alibaba to find its store. Besides, Veichi Electric is a good alternative to Delta. Veichi Electric provides various kinds of VFDs such as air compressor inverter, injection molding machine inverter, mini inverter and more.
Dec 08, 2011 | Delta Electronics - Others
Mitsubishi Electric FR-A720-00610-NA Mitsubishi A700 Variable Frequency Drive, 20HP 240V Logo
Top Mitsubishi Electric Tools & Hardware - Others Experts
Are you a Mitsubishi Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
